John Dirks Jr Posted July 5, 2010 Report Posted July 5, 2010 Can anyone tell me what make and model this unit is? I'd like to find an operators manual for my client. I couldn't find any identifying markings on it. Click to Enlarge 38.66 KB
hausdok Posted July 6, 2010 Report Posted July 6, 2010 Didn't you look at the instruction plate undearneath that panel for the name of the manufacturer? ONE TEAM - ONE FIGHT!!! Mike
John Dirks Jr Posted July 6, 2010 Author Report Posted July 6, 2010 Didn't you look at the instruction plate undearneath that panel for the name of the manufacturer? ONE TEAM - ONE FIGHT!!! Mike I did, there was nothing I could see. I saw the ash box and the blower but not manufacturer plates.
Bill Kibbel Posted July 6, 2010 Report Posted July 6, 2010 I don't recognize that bow front. The gold trim reminds me of older Majestic inserts. What instructions are you looking for? It only has a primary air control and probably a blower speed control. Now that it's a stove insert and not a just a masonry fireplace, you do know there's a different hearth extension requirement?
John Dirks Jr Posted July 6, 2010 Author Report Posted July 6, 2010 I don't recognize that bow front. The gold trim reminds me of older Majestic inserts. What instructions are you looking for? It only has a primary air control and probably a blower speed control. Now that it's a stove insert and not a just a masonry fireplace, you do know there's a different hearth extension requirement? No, I did not know there's different requirement. I won't get far dodging the truth so thanks for letting me know. I know from now on. Is there a standard or is that a manufacturer specific spec?
Greg Booth Posted July 6, 2010 Report Posted July 6, 2010 Just to note....it's important to determine how the insert is connected to the masonry flue. Simply set in place, the top of, and space around, the insert can collect HUGE amounts of creosote.
hausdok Posted July 6, 2010 Report Posted July 6, 2010 Just to note....it's important to determine how the insert is connected to the masonry flue. Simply set in place, the top of, and space around, the insert can collect HUGE amounts of creosote. How do you do that? ONE TEAM - ONE FIGHT!!! Mike
Greg Booth Posted July 6, 2010 Report Posted July 6, 2010 "How to determine if there is a connection to the flue?" I first look to see if it is visible from stove interior-a simple camera shot will often do the trick. In the case of baffles or catalytic converters or any other number of "burn-efficiency enhancers" blocking simple site-lines, I snake in the borescope.
hausdok Posted July 7, 2010 Report Posted July 7, 2010 So, What you are saying is that you do an invasive inspection using special equipment to see into areas that most inspectors otherwise can't normally see. ONE TEAM - ONE FIGHT!!! Mike
Brandon Whitmore Posted July 7, 2010 Report Posted July 7, 2010 What you are saying is that you do an invasive inspection using special equipment to see into areas that most inspectors otherwise can't normally see. I don't use the snake, but use my camera. If I can't confirm how it's hooked up, I recommend it be looked in to during the level 2 inspection that I always recommend.
Greg Booth Posted July 7, 2010 Report Posted July 7, 2010 Having once experienced a roaring chimney fire, fueled by creosote collected on the top and sides of an insert that had been slid into a masonry fireplace (with 12" flue tile) you bet I'll be "invasive". This was 40 years ago, and I have preached about this issue whenever I have had the opportunity.
Hearthman Posted August 8, 2010 Report Posted August 8, 2010 Insert woodstove rating plates are typically on the sides or rear of the firebox. With an insert, you would have to swing the stove out onto the hearth extension to get to it. If the stove has a full length listed liner as it should then this would be virtually impossible without disconnecting the liner. BTW, these liners must include the requisite insulation for the clearance to combustibles in the chimney. You would also need proper floor and mantel protection as prescribed in the listed instructions. Most mfrs. make a bay fron inset so who knows what brand this is without the rating plate. If you find an old stove that does not carry markings indicatiing EPA Phase II emissions certification, you should recommend replacement. HTH
offroadaudio Posted February 7, 2011 Report Posted February 7, 2011 On most inserts you can check things out simply by removing the surround. Then you can see how the insert is connected: 1. slammer install, means no pipe at all, just an open flue from the insert that vents into the masonry chimney - very bad 2. direct connect - a short length of pipe that goes past the smoke shelf to the first clay tile - better, but hard to clean. The pipe has to be rated for installation inside a masonry chimney - usually SS. Additionally, the clay tiles need to be evaluated as usual. 3. Full liner - a SS flex or rigid liner that connects to the flue outlet on the insert and continues the full length of the chimney and terminates at the top with a cap. Sometimes insulated (recommended) sometimes not, but might be required by the manufacture if clay is not up to par or for other reasons.
John Dirks Jr Posted February 7, 2011 Author Report Posted February 7, 2011 On most inserts you can check things out simply by removing the surround. Then you can see how the insert is connected: 1. slammer install, means no pipe at all, just an open flue from the insert that vents into the masonry chimney - very bad 2. direct connect - a short length of pipe that goes past the smoke shelf to the first clay tile - better, but hard to clean. The pipe has to be rated for installation inside a masonry chimney - usually SS. Additionally, the clay tiles need to be evaluated as usual. 3. Full liner - a SS flex or rigid liner that connects to the flue outlet on the insert and continues the full length of the chimney and terminates at the top with a cap. Sometimes insulated (recommended) sometimes not, but might be required by the manufacture if clay is not up to par or for other reasons. John, Are you a chimney "specialist" in my area? Do you do chimney/fireplace masonry work too? If so, send me email or IM.
