John Dirks Jr Posted June 17, 2010 Report Posted June 17, 2010 If under normal conditions there is no current in the grounding system of a house, how does our 3 prong tester determine if the system is grounded or not?
Matt Fellman Posted June 17, 2010 Report Posted June 17, 2010 They just measure a voltage difference across the three possibilites and report if it exists. If there's no ground there's nothing to report... therfore the light is out. Hot - Neutral Hot - Ground Neutral - Ground Here's a cool link that has a lot of good info: http://www.thecircuitdetective.com/test.htm#general
