I'm inspecting a new construction and the customer called in a panic today.
It appears that the framer messed up and the roughing for the bathroom door is to small so the solution is to install a narrower one.
what is the minimum door with allowed by code for a bathroom?
thx
The IRC has no minimum size for a door to a bathroom. There isn't even a requirement that there be a door to a bathroom. Heck, bathrooms aren't even considered habitable spaces.
I'm presently installing a 24" wide door in a little half bath that I'm building in my basement. I'm doing it because I found a bitchin' cool wood panel door for $5 at a yard sale, and I had to put it somewhere. That's a *small* door. But heck, it'll be used 10 times a year.
Which bathroom is it? Hall, master, or half?
How small is the door that they're proposing to put in?
How tough would it be to re-frame the wall?
It is a cottage and it is the master bath on the upper floor
I too assumed that 24" would be fine since there are no appliances i.e. washer / dryer
It looks like it will end up as a 28" in lieu of a 30"
thx
