The color doesn't much matter. When PEX began making appearances in my area, I looked at a house that was plumbed with nothing but blue pipes. I thought a mistake had been made--that red PEX had a higher temperature rating than blue. But when I called a plumber friend, he told me that all PEX piping had the same PSI and temperature ratings, regardless of color.
Is that a chunk of galvanized pipe after the pressure reducing valve?
Is that water 'system' hanging from the drain line?
How is all 'that' supported?
If I recall correctly, there's only one townhouse development in Far Hills; I've done a few there but can't remember see that piping...
I think that development had to satisfy the low income housing requirements for Far Hills; after all you need 10 acres to build a house there.
