This corrosion was only in the bottom portion of the panel. There was a very poor gutter downspout arrangement just above this panel on the exterior. This is also the northwest wall which gets most of the wind driven rain.
Could moisture seeping through the block wall cause this corrosion? Is that the most likely cause here?
49.99 KB
22.02 KB
It's hard to tell from a partial shot, but I would expect corrosion from condensation to be pervasive, not just heavy on the bottom.
I was thinking the same thing, just not as well written.[:D]
See the gutter downspout extension? Its the perforated kind that gets used as drain tile. Wrong material for a downspout extension.
Screw mounting holes drilled in the block will make the water intrusion path that much easier.
45.22 KB
60.63 KB
