Ben H Posted May 4, 2010 Report Share Posted May 4, 2010 Home had some cracks that span the whole house, on both sides. I'm not really sure what to make of it. They stair step down to the lintel then span the whole house. Both sides are the same. Whats going on here? Click to Enlarge 41.03 KB Link to comment Share on other sites More sharing options...
Bill Kibbel Posted May 4, 2010 Report Share Posted May 4, 2010 3 rusty lintels over the window openings are lifting up the gable-end. Link to comment Share on other sites More sharing options...
Mike Lamb Posted May 4, 2010 Report Share Posted May 4, 2010 That's a good photo of lintel failure due to rust. Those lintels need replacement, Ben. When steel rusts, it expands. The brick wall above is being forced outward. This has very slowly become a big problem. Link to comment Share on other sites More sharing options...
Ben H Posted May 4, 2010 Author Report Share Posted May 4, 2010 Thanks guys, I've got a TON of pics of this if anyone needs some. I was afraid it was lintel failure, but wasn't confident enough without some other eyes peeking at it. It's really hard to tell where the waters getting in. Two layers of single, w/ original planks. Not a single weep that I could find. Old facia boards that are wrapped now, couldn't really "get in" to see the condition. I would not be surprized to find rotten wood under that metal. Would you call for a complete lintel replacement? Link to comment Share on other sites More sharing options...
kurt Posted May 4, 2010 Report Share Posted May 4, 2010 Yes. Water always gets in. It's probably not the roof. Could just be around the lintels (originally), but now, it'll suck into the cracks through capillarity. Paint doesn't help. It holds water in, it doesn't keep it out. Link to comment Share on other sites More sharing options...
mgbinspect Posted May 11, 2010 Report Share Posted May 11, 2010 Especially, never recommend caulking the front edge of the lintel under the first course of brick, which will definitely trap moisture in and dramatically accelerate the whole deterioration process. If that junction is caulked and painted now, recommend the sealant be removed. Link to comment Share on other sites More sharing options...
