thomop Posted April 26, 2010 Report Share Posted April 26, 2010 Hi Guys, My name is Phil Thomson from Guardian Roofing here in Australia. My question is does your government support and encourage the use of heat reflecting coatings for both commercial and domestic use. As we become more green conscious, i have been getting many more requests for its use. Will there ever be some sort of rebate? Test by government bodies have agreed with independent tests that the reflective paint does work quite substantially. The paint has a limited life span and obviously will need re-coating again at some stage, but its use can be justified. What are you thoughts? Link to comment Share on other sites More sharing options...
kurt Posted April 26, 2010 Report Share Posted April 26, 2010 Don't expect any Federal (US Gov't.) advocacy, but here in Chicago, we're supposed to use it modified systems, or use a granular modified. Being Chicago, our Buildings Dept. doesn't enforce much; they're too busy dealing with indictments for bribe taking and felonious action by the inspectors. Link to comment Share on other sites More sharing options...
Rocon Posted April 26, 2010 Report Share Posted April 26, 2010 Here in California there is a "cool roof" statute in place. it is part of our title 24 requirements under the CBC (modified IBC). Performance of cool roofs is good and as you say the coating needs to be maintained due both to degradation and also dirt that accumulates through the life of the coating. It is very effective in southern California. Areas farther north, and in colder climates do not benefit as much, buildings in cold zones do not benefit from thawing of snow due to solar gain during the winter. There is some discourse as to how much money it would save. I think some of our fiends in Canada could probably shed some light on this for you. I have seen some documents from the Canadian government dealing with these issues. Link to comment Share on other sites More sharing options...
laurame Posted August 5, 2010 Report Share Posted August 5, 2010 Hi Phil. Glad to see that you started this thread. As for my state, not right now but I do hope that in the near future, local politicians will support green energy systems... that's the least they can do to heal our planet. -- Link deleted by mod Link to comment Share on other sites More sharing options...
TLyons Posted August 18, 2010 Report Share Posted August 18, 2010 Here in Phoenix arizona we use alot of the radiant barrier sheets that reflect up to 97% of the heat in the attic. We have used the reflective paint that reflects arround 70% but only last about 5 years before needing to be redone. Tom http://www.sunriseenergynow.com Link to comment Share on other sites More sharing options...
vegaschk Posted September 7, 2010 Report Share Posted September 7, 2010 Yes i am also in California and what Rocon said is true...Personally I think its good to have these things in place, but it truly only benefits those in warmer climates Link to comment Share on other sites More sharing options...
