Bain Posted April 13, 2010 Report Share Posted April 13, 2010 I checked out a commercial building today that had a three-phase incoming electrical service. No big deals. Nothing out of the ordinary. But a question occurred to me . . . Three-phase electrical services have three hot SE cables coming into the house, hence its name. But the residential stuff we normally see has two hot SE cables servicing the house. So . . . drum roll . . . why is it called single phase? Why not double phase? It is what it is, to invoke a current--pun intended--cliche, but "single phase" seems like a misnomer. Link to comment Share on other sites More sharing options...
Jim Katen Posted April 13, 2010 Report Share Posted April 13, 2010 I checked out a commercial building today that had a three-phase incoming electrical service. No big deals. Nothing out of the ordinary. But a question occurred to me . . . Three-phase electrical services have three hot SE cables coming into the house, hence its name. But the residential stuff we normally see has two hot SE cables servicing the house. So . . . drum roll . . . why is it called single phase? Why not double phase? It is what it is, to invoke a current--pun intended--cliche, but "single phase" seems like a misnomer. Actually, it's quite accurate. There's only one phase. Think of it as an oscillating wave. It has two poles. Three-phase systems actually have three separate phases. They can have many different wire configurations entering the service, not just three. There are some two-phase systems, but you're unlikely to every run into one. They were used, I believe, on railroads and a few large manufacturing facilities. - Jim Katen, Oregon Link to comment Share on other sites More sharing options...
Bain Posted April 13, 2010 Author Report Share Posted April 13, 2010 I checked out a commercial building today that had a three-phase incoming electrical service. No big deals. Nothing out of the ordinary. But a question occurred to me . . . Three-phase electrical services have three hot SE cables coming into the house, hence its name. But the residential stuff we normally see has two hot SE cables servicing the house. So . . . drum roll . . . why is it called single phase? Why not double phase? It is what it is, to invoke a current--pun intended--cliche, but "single phase" seems like a misnomer. Actually, it's quite accurate. There's only one phase. Think of it as an oscillating wave. It has two poles. Three-phase systems actually have three separate phases. They can have many different wire configurations entering the service, not just three. There are some two-phase systems, but you're unlikely to every run into one. They were used, I believe, on railroads and a few large manufacturing facilities. - Jim Katen, Oregon As always, your superior understanding of this stuff is more than a little humbling. I don't quite get it, but I promise to perform some research. Link to comment Share on other sites More sharing options...
Marc Posted April 13, 2010 Report Share Posted April 13, 2010 Jim's right about 2 phase systems. 2 phase has the two phases 90 degrees apart and could mimic 4 phase, but three phase won out several decades ago and became the standard. As for the OP...You can't have a voltage source without a return so that's why there's two conductors for single phase. Hot wire and return. Standard 120/240 V service to a residence is actually a 240 Volt single phase voltage source with the neutral connected to a centertap on the transformer for combined 240/120 volt single phase service. The three phase configuration shares one return for all three sources, which comes out to four wires. When the loading on the three phases is balanced between the 3 phases, such as for a 3 phase motor load, the neutral current is practically zero and becomes redundant and is often omitted to save on conductor. 3 phase service to a residence isn't balanced at all and so it needs that neutral. It's not a dumb question but let me ask you....is this a trick question to get me drawn into another long contentious thread on electrical?[] Marc Link to comment Share on other sites More sharing options...
Bain Posted April 13, 2010 Author Report Share Posted April 13, 2010 It's not a dumb question but let me ask you....is this a trick question to get me drawn into another long contentious thread on electrical?[] Marc Well, actually yes, but it looks like my attempt has failed. I hate it when that happens. I'm kidding, clearly. Your explanation was quite helpful and it makes me understand what's going on phase-wise a little better. Thank you. Link to comment Share on other sites More sharing options...
Chad Fabry Posted April 13, 2010 Report Share Posted April 13, 2010 Jon, That was a great question. Thanks for exposing your soft underbelly for the masses. Link to comment Share on other sites More sharing options...
Bain Posted April 13, 2010 Author Report Share Posted April 13, 2010 Jon, That was a great question. Thanks for exposing your soft underbelly for the masses. Said underbelly was exposed for only the briefest of instants. Beware, for now I have flipped back over and the public's visage is limited to only my prick-ly side. If you're reeaally looking for fodder, read my last FB status-update from a week or so ago . . . . Link to comment Share on other sites More sharing options...
Rob Amaral Posted April 15, 2010 Report Share Posted April 15, 2010 Basic circuit theory.... a complete loop... ... We have to think of basic circuit theory in regards to the distribution system, the house, etc... You probably learn this stuff in Cub Scouts.. (I did). Link to comment Share on other sites More sharing options...
kurt Posted April 15, 2010 Report Share Posted April 15, 2010 I didn't get it then, and I barely get it now. Link to comment Share on other sites More sharing options...
Tom Raymond Posted April 15, 2010 Report Share Posted April 15, 2010 I've got a commercial electrician I can call in for 3 phase stuff. I don't get it, don't want to. Tom Link to comment Share on other sites More sharing options...
Billy_Bob Posted April 15, 2010 Report Share Posted April 15, 2010 Let's see... Look up at the wires on the electric pole... With 3 phase, there are 3 wires coming from the electric power plant. You could say that these 3 wires are coming off the generator from three evenly distributed points on the generator. Or three points around a circle. Then we take those three wires and use them to power an electric motor. THIS power would be like 3 horses walking around a circle and atttached to arms which go to a central rotating shaft. The "power" of the horses is evenly distributed from three points in a circle. And because of this, 3 phase electric motors run more "efficiently". And that is the big benefit with 3 phase power, to run large electric motors for things like air conditioning, elevators, machinery, etc. Things you would find in a business, large building, or industry. For homes, look up at the electric pole again. You will notice just one of those 3 wires being used for the house transformer and from there the wires going to the house. Just one phase is being used. Single phase. Then the transformer does what it can with this single phase. That is to produce "opposites". While one is +, the other is -. Then it switches to where the first is - and the other is +. 60 times a second (60 cycles - or "alternating current"). BUT the two hot wires going to the home are doing their +/- business at the same exact time. Because this comes from that one wire above - just "one" of the phases. As to horses in a circle, I suppose this would be like 1/2 horse going in a circle. And another 1/2 horse going the opposite direction in the circle. (Together they make one horse!) There is a point where they meet and there is a point where they are the farthest apart. (Note: All 3 wires up above that are 3 phase alternate 60 times a second.) 3 phase picture... http://upload.wikimedia.org/wikipedia/c ... rm.svg.png Single phase picture... http://www.electricalknowledge.com/imag ... veform.gif More... http://en.wikipedia.org/wiki/Three-phase_electric_power Link to comment Share on other sites More sharing options...
Chad Fabry Posted April 15, 2010 Report Share Posted April 15, 2010 Nice job Link to comment Share on other sites More sharing options...
Bob White Posted April 15, 2010 Report Share Posted April 15, 2010 My basic electronics training kept me going through my years on submarines (I let the electrician's mates deal with the voltage/current/phasing my equipment used.) In my civilian career I had to learn about three phase five wire wye supplies for the equipment we worked on, and, before I left that field, I was traveling around the country doing power quality surveys at hospitals where our systems were installed. I never worried about sngle phase elect. much (though I did bring some of our test equipment home to scope out the house I was leasing back then (two wire, the only ground was at the service disconnect/panel) --- Since I learned 3 phase, my somewhat autistic mind handles it better when I think of my household single phase as two phase, 180 degrees out .... (edited to remove the typos I caught --- I don't like this laptop keyboard --- not forgiving at all) Link to comment Share on other sites More sharing options...
Bain Posted April 15, 2010 Author Report Share Posted April 15, 2010 Let's see... Look up at the wires on the electric pole... With 3 phase, there are 3 wires coming from the electric power plant. You could say that these 3 wires are coming off the generator from three evenly distributed points on the generator. Or three points around a circle. Then we take those three wires and use them to power an electric motor. THIS power would be like 3 horses walking around a circle and atttached to arms which go to a central rotating shaft. The "power" of the horses is evenly distributed from three points in a circle. And because of this, 3 phase electric motors run more "efficiently". And that is the big benefit with 3 phase power, to run large electric motors for things like air conditioning, elevators, machinery, etc. Things you would find in a business, large building, or industry. For homes, look up at the electric pole again. You will notice just one of those 3 wires being used for the house transformer and from there the wires going to the house. Just one phase is being used. Single phase. Then the transformer does what it can with this single phase. That is to produce "opposites". While one is +, the other is -. Then it switches to where the first is - and the other is +. 60 times a second (60 cycles - or "alternating current"). BUT the two hot wires going to the home are doing their +/- business at the same exact time. Because this comes from that one wire above - just "one" of the phases. As to horses in a circle, I suppose this would be like 1/2 horse going in a circle. And another 1/2 horse going the opposite direction in the circle. (Together they make one horse!) There is a point where they meet and there is a point where they are the farthest apart. (Note: All 3 wires up above that are 3 phase alternate 60 times a second.) 3 phase picture... http://upload.wikimedia.org/wikipedia/c ... rm.svg.png Single phase picture... http://www.electricalknowledge.com/imag ... veform.gif More... http://en.wikipedia.org/wiki/Three-phase_electric_power Wicked helpful, Billy Bob. Thanks. Link to comment Share on other sites More sharing options...
