Levis Posted April 8, 2010 Report Share Posted April 8, 2010 I want to convert my Simple water heating system to Solar Water Heating System. Is SolVelox is the best technology to convert your existing water heating system to Solar Water Heating System? if yes , why? Link to comment Share on other sites More sharing options...
Tom Raymond Posted April 8, 2010 Report Share Posted April 8, 2010 After a (very) brief cruise through their website it looks to me like you will need to keep your existing water heater for back up and run the solar system along side it. I know of only one company that makes a heat exchanger that will fit into any existing water heater tank, sunmaxx solar. The advantages are; your solar storage and domestic hot water are in the same vessel saving lots of space, the controls are very simple, and back up is automatic. Solar thermal is highly scalable, but for domestic hot water keep it as simple as possible. Tom Link to comment Share on other sites More sharing options...
john_opwin Posted April 12, 2010 Report Share Posted April 12, 2010 Obviously you can get it done, just take an advise from your nearer knowledgeable person. Link to comment Share on other sites More sharing options...
TLyons Posted August 18, 2010 Report Share Posted August 18, 2010 Another option you could look at would be a passive system which ties right into your existing water heater gas or electric.Benifits no moving parts, no pumps gravity fed. Down side not quite as efficient doen't circulate the water just preheats it into waterheater. Tom (link removed) Link to comment Share on other sites More sharing options...
spider Posted January 10, 2012 Report Share Posted January 10, 2012 Solar water heating (SWH) or solar hot water (SHW) systems comprise several innovations and many mature renewable energy technologies that have been well established for many years. SWH has been widely used in Greece, Turkey, Israel, Australia, Japan, Austria and China.In a "close-coupled" SWH system the storage tank is horizontally mounted immediately above the solar collectors on the roof. No pumping is required as the hot water naturally rises into the tank through thermosiphon flow. In a "pump-circulated" system the storage tank is ground or floor mounted and is below the level of the collectors; a circulating pump moves water or heat transfer fluid between the tank and the collectors. (link removed) Link to comment Share on other sites More sharing options...
