David Meiland Posted April 6, 2010 Report Share Posted April 6, 2010 Curious if any of you are seeing Pro-Press fittings on copper pipe, and if so, what if anything you've observed? Link to comment Share on other sites More sharing options...
MTL_Inspet_Man Posted April 6, 2010 Report Share Posted April 6, 2010 I've seen a presentation done by one of the local reps here. Haven't come across any installations yet. I guess it's like everything else there will be a learning curve. Best thing for inspectors I guess is to get as much info from a local rep and maybe they can refer a contractor who is using the system and go see an installation in progress. Link to comment Share on other sites More sharing options...
kurt Posted April 6, 2010 Report Share Posted April 6, 2010 I've seen a couple installations on heating systems. They work. I am, of course, skeptical on the long term, but that's just me. Link to comment Share on other sites More sharing options...
hausdok Posted April 6, 2010 Report Share Posted April 6, 2010 I've seen them used for both potable water plumbing and for hydronic heating systems. Very nice. ONE TEAM - ONE FIGHT!!! Mike Link to comment Share on other sites More sharing options...
Ben H Posted April 6, 2010 Report Share Posted April 6, 2010 Are we talking about the "shark-bite" style fitting? Link to comment Share on other sites More sharing options...
kurt Posted April 6, 2010 Report Share Posted April 6, 2010 Sharkbites are a push on type; ProPress have a proprietary compression tool. Link to comment Share on other sites More sharing options...
hausdok Posted April 6, 2010 Report Share Posted April 6, 2010 No, He's talking about a Viega copper pipe system where the fittings come with a rubber seal preinstalled and when the pipe is assembled a pneumatic press tool is used to crimp the fittings to the pipe. No soldering involved. Go here. The system can be used for potable, radiant or gas and they even have a stainless steel system. ONE TEAM - ONE FIGHT!!! Mike Link to comment Share on other sites More sharing options...
kurt Posted April 6, 2010 Report Share Posted April 6, 2010 http://www.sharkbiteplumbing.com/ Ain't them Sharkbites? Viego is Viego ProPress, ain't it? Link to comment Share on other sites More sharing options...
plummen Posted April 6, 2010 Report Share Posted April 6, 2010 i saw a tee being installed on a 3" water service last week using the pro press method with water still drippin out the lines before it was installed,no leaks after fitting was installed. no way that fitting could of been soldered with water in it,i was very impressed! [] Link to comment Share on other sites More sharing options...
Terence McCann Posted April 6, 2010 Report Share Posted April 6, 2010 i saw a tee being installed on a 3" water service last week using the pro press method with water still drippin out the lines before it was installed,no leaks after fitting was installed. no way that fitting could of been soldered with water in it,i was very impressed! [] Jim, I sent a private PM a while ago but perhaps it got lost in the mail. Seeing as W.J. isn't around anymore I guess I'll pick up a bit of the slack. Pick up a book on correct sentence structure. Folks will put a lot more stock in what you say if you're at least trying to make an effort at proper writing skills. We're professionals. Link to comment Share on other sites More sharing options...
plummen Posted April 8, 2010 Report Share Posted April 8, 2010 Like I said in my reply to your message. I tend to worry more about the quality of the work I do than how good of a wordsmith I am! Personally id rather find an inspector or contractor who knows how to find problems and repair them correctly than a guy who spells really good ,but burns down or floods houses myself! but Im working on it just for your peace of mind! [:-monkeyd Link to comment Share on other sites More sharing options...
Ben H Posted April 8, 2010 Report Share Posted April 8, 2010 DO they make a "bolt cutter" style crimp tool, or do I have to buy a $1,800.00 Rigid battery powered gun? [:-crazy] Looks like a very cool system... Link to comment Share on other sites More sharing options...
Terence McCann Posted April 8, 2010 Report Share Posted April 8, 2010 Like I said in my reply to your message. I tend to worry more about the quality of the work I do than how good of a wordsmith I am! Personally id rather find an inspector or contractor who knows how to find problems and repair them correctly than a guy who spells really good ,but burns down or floods houses myself! but Im working on it just for your peace of mind! [:-monkeyd My bad - I truly thought the PM didn't get to you but I see now that it did. I'm sorry. Link to comment Share on other sites More sharing options...
plummen Posted April 8, 2010 Report Share Posted April 8, 2010 No problem,back to the war on code violations! [:-thumbu] Link to comment Share on other sites More sharing options...
