Erby Posted March 27, 2010 Report Posted March 27, 2010 I didn't measure it. Ooopps. Do you think the trap arm length is long enough. Click to Enlarge 42.36 KB -
Brandon Whitmore Posted March 27, 2010 Report Posted March 27, 2010 Doesn't matter as it's not vented properly. The weir must not be higher than the vent opening, so I think you're safe to call it out. I'm pretty sure you already knew that though. I believe that the arm only has to be 2x the diameter of the pipe. That pipe looks like a 2", so it looks fine to me other than the venting issue.
plummen Posted March 28, 2010 Report Posted March 28, 2010 san-tee laying on its back is a no-go around here also,s-trap is also a no-go...........
