Jerry Lozier Posted March 12, 2010 Report Posted March 12, 2010 My Ideal Suretest 61-165 went south, off warranty and $150 from company to evaluate. $250+ to replace... I use it a few times a month mostly on older homes with 3 prong that show they have a ground. Find bootlegs often... Rarely use the gfci/ afci trip mode as I trip at outlet or the breaker, so don't need really that function Anyway... does anyone use any other detector that reveals false grounds, that may be cheaper and maybe not quite as bulky??????? Sure I could pull the cover but I like quick better if possible Jerry
Richard Moore Posted March 13, 2010 Report Posted March 13, 2010 Jerry, before you go any further, you might try unscrewing the case, pull it apart as much as possible and check the soldered conections from the male cord-plug pins to the circuit board. I've had a couple of Suretests go bad or touchy on me and found cracked solder on both of them. A quick touch up with a soldering iron and solder fixed them. I haven't had any more trouble since I got rid of the fairly stiff cord the unit comes with and replaced it with a softer and slightly longer one I found somewhere(?). The old cord would dangle from my pouch and occasionally get caught on things, which may have led to the damage. The new one I am able to wrap around the unit itself and the whole thing fits, better protected, in a tool belt pouch. Or...you might just have a bad unit.
hausdok Posted March 13, 2010 Report Posted March 13, 2010 Also, When you open it, if you pull the screws that hold the circuit board in place and turn it over, you'll find a little tiny transformer about 1/4 inch in diameter with a U-shaped plastic cover snapped in place over it. The hair-thin wires to the corner of that transformer will break off. I've brought mine into a TV repair shop several times to have that tiny wire connection repaired. The last time, they bedded the transformer in some kind of gooey stuff and then I wadded up a piece of kleenex and reinstalled it with the kleenex wedged between the housing and the transformer to hold it firmly in place. Haven't been back to that TV repair shop in a few years now. ONE TEAM - ONE FIGHT!!! Mike
Jerry Lozier Posted March 13, 2010 Author Report Posted March 13, 2010 thanks guys.... I'll try that... nothing to lose. I know what you mean Richard, about the stiff cord, that was the first thing I did was found another cord (thinner and longer) to test the unit, nothing changed but if the repair works out I think will get a more flexible cord.. thanks for the advice
randynavarro Posted March 13, 2010 Report Posted March 13, 2010 hausdok said: Also, When you open it, if you pull the screws that hold the circuit board in place and turn it over, you'll find a little tiny transformer about 1/4 inch in diameter with a U-shaped plastic cover snapped in place over it. The hair-thin wires to the corner of that transformer will break off. I've brought mine into a TV repair shop several times to have that tiny wire connection repaired. The last time, they bedded the transformer in some kind of gooey stuff and then I wadded up a piece of kleenex and reinstalled it with the kleenex wedged between the housing and the transformer to hold it firmly in place. Haven't been back to that TV repair shop in a few years now. ONE TEAM - ONE FIGHT!!! Mike Hmm. Sounds vaguely familiar to the same repair story you tell about your Protimeter. Are you sure you're not confusing the two? Remember, Suretest is for ELECTRICAL and Protimeter is for MOISTURE.
Jim Katen Posted March 13, 2010 Report Posted March 13, 2010 Jerry Lozier said: . . . Anyway... does anyone use any other detector that reveals false grounds, that may be cheaper and maybe not quite as bulky??????? Sure I could pull the cover but I like quick better if possible If you're only interested in false grounds, I'll bet that for a quick trip to Radio Shack, $20, and a hour of your time, you could make something. - Jim Katen, Oregon
hausdok Posted March 13, 2010 Report Posted March 13, 2010 randynavarro said: hausdok said: Also, When you open it, if you pull the screws that hold the circuit board in place and turn it over, you'll find a little tiny transformer about 1/4 inch in diameter with a U-shaped plastic cover snapped in place over it. The hair-thin wires to the corner of that transformer will break off. I've brought mine into a TV repair shop several times to have that tiny wire connection repaired. The last time, they bedded the transformer in some kind of gooey stuff and then I wadded up a piece of kleenex and reinstalled it with the kleenex wedged between the housing and the transformer to hold it firmly in place. Haven't been back to that TV repair shop in a few years now. ONE TEAM - ONE FIGHT!!! Mike Hmm. Sounds vaguely familiar to the same repair story you tell about your Protimeter. Are you sure you're not confusing the two? Remember, Suretest is for ELECTRICAL and Protimeter is for MOISTURE. D'oh!!! Yep, disregard - I got 'em mixed up. I swear, alzheimers or somethin... ONE TEAM - ONE FIGHT!!! Mike
Marc Posted March 13, 2010 Report Posted March 13, 2010 hausdok said: Yep, disregard - I got 'em mixed up. I swear, alzheimers or somethin... ONE TEAM - ONE FIGHT!!! Mike Welcome to the club Mike. I fend off my memory problems by jogging. Immediate improvement. Never known a rigorously active person to have alzheimers. Not one. Pardon the drift. Marc
Ben H Posted March 13, 2010 Report Posted March 13, 2010 Mike, that gooey stuff...is it hard? If so it's more than likely just hot glue.
Marc Posted March 13, 2010 Report Posted March 13, 2010 My experience in Radio/TV service tells me that it isn't a good idea to put a hot glue gun to such a small transformer. The heat may either ruin the transformer insulation or delaminate the foil conductors on the PC board. It's a mess if you need to change the transformer later too. Marc
kurt Posted March 13, 2010 Report Posted March 13, 2010 Jim Katen said: If you're only interested in false grounds, I'll bet that for a quick trip to Radio Shack, $20, and a hour of your time, you could make something. - Jim Katen, Oregon Since I limit most of my experimentation to things that float on water, pray tell......... How might I do that?
Ben H Posted March 13, 2010 Report Posted March 13, 2010 Marc said: My experience in Radio/TV service tells me that it isn't a good idea to put a hot glue gun to such a small transformer. The heat may either ruin the transformer insulation or delaminate the foil conductors on the PC board. It's a mess if you need to change the transformer later too. Marc Just a dab is all you'll need. There is no need to cover it in a pile of hot glue. Just keep it from vibrating around and creating a cold solder break/leg failure. Once it's cold, it will pop right off with very little force.
hausdok Posted March 13, 2010 Report Posted March 13, 2010 Ben H said: Mike, that gooey stuff...is it hard? If so it's more than likely just hot glue. Nah, it resembled a thick urethane non-hardening caulk then it did hot glue. ONE TEAM - ONE FIGHT!!! Mike
Jim Katen Posted March 13, 2010 Report Posted March 13, 2010 kurt said: Jim Katen said: If you're only interested in false grounds, I'll bet that for a quick trip to Radio Shack, $20, and a hour of your time, you could make something. - Jim Katen, Oregon Since I limit most of my experimentation to things that float on water, pray tell......... How might I do that? Heck, I don't know. But I'll bet that, given a little time, you could figure it out. All you need to do is to be able to measure the resistance between the netural and the ground. If the resistance is greater that that of a 5' length of #14 wire, you're good. If the resistance is less, you've got a high chance of a bootleg ground. - Jim Katen, Oregon
John Kogel Posted March 14, 2010 Report Posted March 14, 2010 Quote Originally posted by Jim Katen] Heck, I don't know. But I'll bet that, given a little time, you could figure it out. All you need to do is to be able to measure the resistance between the netural and the ground. If the resistance is greater that that of a 5' length of #14 wire, you're good. If the resistance is less, you've got a high chance of a bootleg ground. - Jim Katen, Oregon Sounds like a multimeter will do. You could make an attachment for it from a 3-prong plug. That would be bulky,though. You would run one lead of the meter to the neutral prong and the other to the grounding prong, and set it to measure ohms. Too low of a reading is a heads up, neutral could be shorted to ground. This test would be useless anywhere close to the panel, where the resistance of the ground lead would naturally be low.
kurt Posted March 14, 2010 Report Posted March 14, 2010 I'm such an idiot with this stuff...... Can you 'splain it with pictograms?
Terence McCann Posted March 14, 2010 Report Posted March 14, 2010 John Kogel said: Sounds like a multimeter will do. You could make an attachment for it from a 3-prong plug. That would be bulky,though. You would run one lead of the meter to the neutral prong and the other to the grounding prong, and set it to measure ohms. Too low of a reading is a heads up, neutral could be shorted to ground. This test would be useless anywhere close to the panel, where the resistance of the ground lead would naturally be low. If you did use a MM you wouldn't need a 3-prong attachment, just put one lead in the netural and one in the ground and have the meter set to measure ohms. However I wouldn't do it with the power on as you might smoke the meter. Also, I think this would only work on home that has an older system like K&T (without a ground).
