cjay876 Posted February 3, 2010 Report Share Posted February 3, 2010 well this is whats going on. i have a customer who is doing an addition to his house and he needs is service drop to be move to the other side of his house temporarily (they are still living at home.)also when its all said and done he will be upgrading to 400 amps. i was planning to put a few 4x4x16 poles off to the side to mount his service drop and that would fix the problem... whats the maximum distance i can have the poles a part. article "225.6.A" would apply right? P.S. can't put a temp pole they will be living at the home during the process and need all there electrical to be intact Link to comment Share on other sites More sharing options...
Jack Davenport Posted February 3, 2010 Report Share Posted February 3, 2010 anything before the meter ,including the meter, belongs to the electric utility. Thus anything before the meter is not covered by the NEC as utilities are except from the NEC as far as electrical distribution is concerned. NEC article 90.2 (B)(5) explains this. Link to comment Share on other sites More sharing options...
Bill Kibbel Posted February 3, 2010 Report Share Posted February 3, 2010 anything before the meter ,including the meter, belongs to the electric utility. Thus anything before the meter is not covered by the NEC as utilities are except from the NEC as far as electrical distribution is concerned. NEC article 90.2 (B)(5) explains this. That's not the case here. The service entry cable and meter box do not "belong to the electric utility". Link to comment Share on other sites More sharing options...
Tom Raymond Posted February 3, 2010 Report Share Posted February 3, 2010 anything before the meter ,including the meter, belongs to the electric utility. Thus anything before the meter is not covered by the NEC as utilities are except from the NEC as far as electrical distribution is concerned. NEC article 90.2 (B)(5) explains this. That's not the case here. The service entry cable and meter box do not "belong to the electric utility". Same here, except that some utilities require you to purchase their meter box. That was the case when I did my service 10 years ago anyway. Tom Link to comment Share on other sites More sharing options...
RobC Posted February 3, 2010 Report Share Posted February 3, 2010 As a Masters Electrican/Control Tech, perhaps you could tell us. Link to comment Share on other sites More sharing options...
Billy_Bob Posted February 3, 2010 Report Share Posted February 3, 2010 Around here, the electric company has on its web site "Electric Service Requirements". And when looking for this on their web site, they show different rules for each state. So check your local electric company web site. And be sure you are looking at the rules for your state if the electric company serves several states. Also you can call them up and they should be able to send out someone who can tell you what they can / can't do. FYI - Pacific power Electric Service Requirements for Washington, Oregon, California, Utah, Idaho, Wyoming... http://www.pacificpower.net/con/esr.html Link to comment Share on other sites More sharing options...
Jack Davenport Posted February 3, 2010 Report Share Posted February 3, 2010 Is this a temporary install or a permanent one? You said the service drop - which is the utilities overhead lines prior to the meter. From the meter in it's yours. Are you talking about relocating the overhead lines as well as the meter and cable to the panel ? If it's a temp install just put enough to keep it up. If it's a permanent I wouldn't use 4x4's Explain exactly what you are doing Link to comment Share on other sites More sharing options...
cjay876 Posted February 3, 2010 Author Report Share Posted February 3, 2010 Scope home inspection....ignorance is not bliss, me being a master electrican/control tech don't mean i know everything that's why i ask question when i'm not sure..... how the this thing came up, was the utility company told me it was my responsibility to provide a temporary support for the service since the meter base is not being moved. The addition is starting where the original service drop was. so the service drop is temporary untill the addition is finish. Link to comment Share on other sites More sharing options...
Bill Kibbel Posted February 3, 2010 Report Share Posted February 3, 2010 I don't know of any required intervals. Back in the day, we just made sure the service drop was 12' above the ground and 15' above where vehicles traveled through the site. There was one type of front-discharge concrete trucks that required a little more clearance. Two 2x4-16's held by laborers did the trick. Link to comment Share on other sites More sharing options...
Jim Port Posted February 4, 2010 Report Share Posted February 4, 2010 If the utility said it was up to you to install the support pole the correct design should be in their design manual that is commonly available online. Most places here would be at least a 6x6x16 or so. Link to comment Share on other sites More sharing options...
cjay876 Posted February 5, 2010 Author Report Share Posted February 5, 2010 Problem solved....4x4x16 held by laborers. its connected and now its on to the easy stuff.... thanks for all the help. Link to comment Share on other sites More sharing options...
