After about 13 years, this is a first for me.
My question would be is the fan changed; after all a cat III is 'under pressure' while a cat I is 'atmospheric'.
44.52 KB
Just a wild guess; but a 3-inch vent is consistent in size from the boiler to terminus. so pressure ranges within the vent are probably equal anywhere along its length. However, when you vent into a chimney using a short connector the chimney flue will be far larger, and can vary in size along its length, so the atmospherics would be inconsistent from boiler to terminus.
I don't recall having ever seen that either.
There was a thread a few weeks ago regarding an attic-mounted furnace that vented horizontally. I was emphatic about that furnace being a category I unit. Now I wonder.
What make & model is the furnace in that picture?
It's a Peerless Boiler. Excuse the out of focused spec plate photo.
57.76 KB
40.23 KB
33.45 KB
The PVC is the gas water heater exhaust.
64.55 KB
There's no change of fan.
If venting into a chimney, the flue connector dimension is increased to significantly reduce internal pressure. An increaser would be installed on the 3" fan adapter and a 5" vent connector would be installed.
