Roof Repair St Petersburg Posted January 1, 2010 Report Posted January 1, 2010 Inspections are key. It's extremely important to inspect your roof at least twice a year, in order to prevent any unseen damage from becoming a disaster. Regular inspections will also help you to quickly recognize anything that seems different or odd about your roof. There are some basic things you can look out for that will tell you whether you have a happy, healthy roof, or whether you need to call in a roofing company for a roof repair. Missing or broken shingles are an obvious sign of a problem. Empty spots could allow moisture to collect and puddle, eventually soaking through and becoming a leak. Don't hesitate to have a roofing company come and check out potential leaks, as they'll only get worse with time. Steep roofs tend to lose more shingles due to high winds.
hausdok Posted January 1, 2010 Report Posted January 1, 2010 Hi, I've removed the link from your signature. What you've posted is first hour in training info for a good home inspector. It's not bringing anything to the table and it's obviously aimed at consumers. This is not a link seeding venue. This is a home inspectors' forum. If you want to provide info that's useful to home inspectors, by all means do so; we welcome input from the professions. ONE TEAM - ONE FIGHT!!! Mike
