Chad Fabry Posted September 29, 2004 Report Share Posted September 29, 2004 After researching some I've discovered that some of the areas I cover are known to be high in radon. It sort of goes against my grain to offer this service, but I just lost a job because I don't. I've looked into equipment like the Sun Nuclear set up and it's affordable enough so that I'd be interested in the investment, and I've read the manuals and it doesn't seem beyond my scope of ability. Are there requirements for testing in NY? I would do a "dual test" one test would be lab evaluated, with the Sun test being a back up to show that the area was unventilated for the duration of the test. What do you seasoned vets think? Link to comment Share on other sites More sharing options...
Terence McCann Posted September 29, 2004 Report Share Posted September 29, 2004 I own multiple Sun Nuclear's. I don't do a lot of Radon testing (although two this week) but it is a service I think we should offer, even if it might be a lost leader. Check the NY state web site Chad for more info on licensing. Link to comment Share on other sites More sharing options...
Chad Fabry Posted September 29, 2004 Author Report Share Posted September 29, 2004 loss leader? I don't do loss leaders. Nope, no sir. I have a line item on my ledger for pens. They cost .009 dollars per inspection. That adds up to nearly 3 dollars a year. I have to cover expenses damnit. Signature left off this post so no one googling my name will run across it. Link to comment Share on other sites More sharing options...
Tom Barber Posted September 29, 2004 Report Share Posted September 29, 2004 Chad Before you make a final decision check out Radalink.com the testing unit is great, the report is very professional and the support is even better. There is little to no start up cost and the flat rate monthly fee makes it very affordable. I have been a Radalink user for 8 years and would not change if I was paid to. Tom Barber in VA Link to comment Share on other sites More sharing options...
Chad Fabry Posted September 29, 2004 Author Report Share Posted September 29, 2004 Thanks Tom, I'll look into that. Update: I can use the charcoal cans w/ no license and or permits, but to use the electronic systems that are out there I'm essentially a "lab" and for that there are requirements. I have to apply to NYS and the application and competency test costs five hundred, yes that's right, five hundred dollars. Once I apply I must pass two more tests each of which has another fee attached. Then I can wait 60 to 90 days for scoring and approval then I can test for radon. Piece of cake. Link to comment Share on other sites More sharing options...
Tom Barber Posted September 29, 2004 Report Share Posted September 29, 2004 Chad, With Radalink you are a secondary not a primary tester, which may or may not solve your problem. But either way, just to cover your butt I strongly recommend that you become either NEHA or NRSB certified. Tom Barber in VA Link to comment Share on other sites More sharing options...
Chad Fabry Posted September 30, 2004 Author Report Share Posted September 30, 2004 Thanks Joe, I'm researching it all right now and I have the application on it's way in the mail. My next inspection fee is getting banked for the charges to get approved by the state. I haven't told my wife yet, so don't let this slip in conversation. Link to comment Share on other sites More sharing options...
Bruce Thomas Posted September 30, 2004 Report Share Posted September 30, 2004 Chad, It's very important to have good training and equipment for radon testing just like home inspection. Look into www.aarst.org. Tons of info and help if you need it. Also look into E-PERMS. Higher up front than sun but less expensive per test but you do have the lab thing with them. I whsh PA was as easy as NY to become certifeid. By the way radon testing is about 20% of our income. Also got to www.radon.com and type in your zip code to see the average levels in your area. The ERA also has a national map http://www.epa.gov/iaq/radon/zonemap.html Also call your insurance carrier to be sure that you are covered for testing. Other than that nothin' to it. Let me know if you get confused or need help. Bruce Founding President Tri-State AARST chapter. Link to comment Share on other sites More sharing options...
bradfeldt Posted September 30, 2004 Report Share Posted September 30, 2004 We have used Radalink for about six years now and never had a problem. If you are in a licensed state they will assist you in jumping through all of the hoops necessary. They also provide you with all of the forms, quality control, and calibrations. I believe we pay $75 a month and $25 per test. Doing just a few tests a year easily pays for itself. They also answer all clients questions and interpret the test results for you. Link to comment Share on other sites More sharing options...
Les Posted October 1, 2004 Report Share Posted October 1, 2004 We have a dozen or so Sun devices. Had them for years and no problem other than the pin printers burning up when left on and annual calibration costs. I am about to make an "executive decision" and may get out of the business. We might just concentrate on inspecting existing systems and re-testing. It was always a temptation to test, install, retest. Most radon guys around here screen, find radon, install a system, take the money, then run. The longer I am in this business, the more comfortable I am with just being the best home inspector possible and let the newer guys do everything else. We train and get constant continuing education so we can bring a little extra to a regular inspection. The newer guys think I've gone soft and want to do everything. I have my hands full just inspecting and leave Mold, lead, asbestos, uffi, eifs, water, septics, radon, etc. to the experts. I do give political advice at night and weekends. Link to comment Share on other sites More sharing options...
Darren Posted October 2, 2004 Report Share Posted October 2, 2004 Les, If you do give it up let me know, I may take a few monitors off your hands. Darren About The House Succasunna, NJ Link to comment Share on other sites More sharing options...
Norm Posted November 22, 2004 Report Share Posted November 22, 2004 Several articles appeared yesterday, Sunday November 21, 2004, in the Sun-Sentinel. Go to http://www.sun-sentinel.com enter "radon" in the search box. Remember Florida is relatively radon poor. NORM SAGE Link to comment Share on other sites More sharing options...
