Richard Moore Posted January 7, 2004 Report Posted January 7, 2004 Tomorrow I am having my waste disposal system inspected by video-scope via the rear clean-out. Itââ¬â¢s just highly recommended routine maintenance as the surrounding structure is over 50 years old. Hopefully there will be no need for further evaluation, sample analysis, or invasive and destructive testing by licensed and qualified specialists. While the procedure itself is straightforward, preparation requires that no solids be ingested at the intake for two days and that the system be purged, not once but twice. This is difficult as the controlling mechanism is programmed to demand fuel on a regular basis. Thereforeâ⬦Iââ¬â¢m kind of grumpy! Richard The good news is that I will not be posting any pictures.
kurt Posted January 8, 2004 Report Posted January 8, 2004 Richard, you're cracking me up[:-smile_green]. Thanks for not posting pictures, & hope the system is clean & in sound condition.
allspec33351 Posted January 8, 2004 Report Posted January 8, 2004 Richard If you feel two hands on your back during the procedure,[!] I would suggest a different inspector. [}}>>]
Brian G Posted January 8, 2004 Report Posted January 8, 2004 Originally posted by Richard MooreWhile the procedure itself is straightforward, preparation requires that no solids be ingested at the intake for two days and that the system be purged, not once but twice. That sounds like a diet my wife was on once. [-crzwom] [:-crazy] Brian G. Despiser of Goofy Diets [:-grumpy]
hausdok Posted January 8, 2004 Report Posted January 8, 2004 My sympathies, I went through it in October. 2 polyps removed. Jeesh. They can send little radio operated cars to mars and drive 'em via remote control, why can't they figure out a better way to do this kind of thing? ONE TEAM - ONE FIGHT!!! Mike
swarga Posted January 8, 2004 Report Posted January 8, 2004 I feel for you. I had the same inspection Dec. 6. That fleets stuff that you need to put into the system first should be illegal. I found out that the system seems to reject the fleets less when combined with a chemical commonly referred to as ginger-ale. I hope every thing comes out alright in the end.
Chad Fabry Posted January 8, 2004 Report Posted January 8, 2004 Hope it went well Richard, hopefully it wasn't the inspection where it's necessary to inflate the system to allow access for the video probe.
Richard Moore Posted January 9, 2004 Author Report Posted January 9, 2004 Plumbing Inspection Report Conditions: 98°F, sun not shining. Description: Self contained waste system (no hookup to city sewer) located in 1949 mobile home. Method of Inspection: Access hatch inadequate for physical entry. Inspection conducted using flexible bore-scope (model U.P. Uranus II). Findings: Design was typical of this type of structure. One small anomaly was detected and removed otherwise no significant defects were observed that might adversely affect the function or drainage of the system. Pressure relief valve was tested at the conclusion of the inspection and found to be in good working order (although somewhat noisy). Although the inspection was limited to the plumbing it was observed that the overall structure was bulging a little at the midpoint. This might be due to lack of proper maintenance or excessive fuel intake. Recommendations: Suggest next inspection be scheduled for 2009. Meanwhileâ⬦re-fueling can resume immediately although quantities could perhaps be reduced. End of report. -------------------------- PSâ⬦Thanks guys! Richard
Jerry Simon Posted January 9, 2004 Report Posted January 9, 2004 Richard...good to hear the inspection went well...and....you're one helluva funny guy!
kurt Posted January 9, 2004 Report Posted January 9, 2004 DEFINITELY! I'm still laughing........ Glad to hear you're OK, bud[:-thumbu]
hausdok Posted January 9, 2004 Report Posted January 9, 2004 Which? The laugh or the waste disposal system inspection? [:-dev3] OT - OF!!! M.
Chad Fabry Posted January 9, 2004 Report Posted January 9, 2004 Thanks for the laugh Richard..that was beautiful.
Terence McCann Posted January 9, 2004 Report Posted January 9, 2004 Very funny stuff - was that in the doctors boilerplate? Glad everything went well though!
