At our home we get our water from a roof collection/cistern system. We have a UV purifier and two filters. I just added the second filter because we were having trouble with grit keeping the valves in the toilets from closing. We had been using just a 10 micron. Is a 5 micron filter small enough to stop the problem? Is there a standard regarding this? Thanks
I have a 5 micron whole house sediment filter that has stopped very fine silt and rust. Less than 5 microns is getting into carbon block filters.
Class I >.5 microns
Class II 1-5 microns
Class III 5-15 microns
Class IV 15-30 microns
Class V 30-50 microns
Class VI >50 microns
The only other "standard" is filters should be NSF certified.
Thanks, Bill, I assume that the carbon block filters don't fit into into the same casings as the typical 10" filter does. Ed
Class I >.5 microns
