Jeff Beck Posted November 7, 2009 Report Share Posted November 7, 2009 The townhouse I inspected earlier in the week had aluminum framed sliders. The movable sections had significant fogging as did a sliding door. Has anyone had experience with the companies that defog thermal pane windows and doors? Does the frame material have any effect (aluminum versus wood or vinyl)? Do they replace the desiccant? Thanks Jeff Beck Link to comment Share on other sites More sharing options...
Jim Katen Posted November 7, 2009 Report Share Posted November 7, 2009 The townhouse I inspected earlier in the week had aluminum framed sliders. The movable sections had significant fogging as did a sliding door. Has anyone had experience with the companies that defog thermal pane windows and doors? Does the frame material have any effect (aluminum versus wood or vinyl)? Do they replace the desiccant? Thanks We had a rep from one of those companies speak at a chapter meeting a while back. If the window is fogged to the point where the glass is etched, it can't be fixed. The outer frame -- aluminum, vinyl, or wood -- makes no difference. They don't replace the dessicant. However, you're talking about glass doors. That means that the glass is tempered. These companies fix the windows by drilling small holes in the glass. You can't do that with tempered glass. Personally, I'd just recommend replacing the entire door assembly, but then I detest aluminum-framed sliders. - Jim Katen, Oregon Link to comment Share on other sites More sharing options...
Jeff Beck Posted November 8, 2009 Author Report Share Posted November 8, 2009 Thanks Jim, The whole complex had aluminum doors and windows. A great many beer cans gave up their lives so that this complex could have fogged windows and sliders. Jeff Link to comment Share on other sites More sharing options...
