Bryan Posted October 22, 2009 Report Posted October 22, 2009 Can any one point me to a code reference regarding the minimum distance real wood siding and painted wood trim should be held off of roof shingles? Bryan
hausdok Posted October 22, 2009 Report Posted October 22, 2009 Yep, Go here, save it to your documents folder so you'll have it in the future. Look on the bottom of Page 10 http://www.wrcla.org/pdf/WRCLA_Installing_Siding.pdf ONE TEAM - ONE FIGHT!!! Mike
RobC Posted October 22, 2009 Report Posted October 22, 2009 Page 8/16 "Insulated Concrete Forms (I.C.F.) These systems have no wood component and the foam has no nail holding capacity. As a result, Insulated Concrete Forms require furring strips of a minimum of 1¼ inches thick spaced 16 inches on center on the outside of the foam. Note these will need to be securely fastened to the concrete." No Cladding can be attached to plastic webs. Screws are recommended as they have better pull out resistance than nails. Oddly enough with ICF the need for a weather barrier is not required.
Brandon Whitmore Posted October 26, 2009 Report Posted October 26, 2009 Thanks for the link Mike. I'm sure it's a typo with their literature, but it shows that trim needs a min. 2" clearance to decks, but doesn't seem to say siding? A week ago, I wrote up a deck where surface boards were directly butted up against the siding. While the ledger was flashed, I wrote it up as a concern that could cause future damage. The seller's side has had to contractors out stating that it is fine, and any repairs they do may end up causing problems. I am in the process of finding an authoritative source that can't be argued. Any ideas?
