Yahawahay Posted October 19, 2009 Report Posted October 19, 2009 I have this 4month old install of a copland high temp fractional copland compressor in which I installed. the old compressor locked up on mechanical failure. I believe I correctly installed this one, yet, it failed with S to G short. This is my SOP for the last. 1. Check for Correct voltege @ Control box. 2. Check Ohms across C S R & G (no shorts or open windings) 3. apply Hard Start Cap. 4. Finally Bump compressor..which worked for second.. with loud hard knock noise then lock up.. tripping breaker. I Replaced the compressor with equal tonnage and manufacturer. after blowing out line with Nitogen and installing suc and liq. line dryers. Now. I have a compressor that is short S to G after a misily 4 months. My question is.... is there anything I could have done diff. to prevent this early electrical Issue?[:-banghea
hausdok Posted October 19, 2009 Report Posted October 19, 2009 Hi, You are in completely the wrong venue for this question. I recommend you go over to HVAC Talk. They guys over there eat and breath this king of thing. http://hvac-talk.com/vbb/ ONE TEAM - ONE FIGHT!!! Mike
Terence McCann Posted October 19, 2009 Report Posted October 19, 2009 Yahawahay said: I have this 4month old install of a copland high temp fractional copland compressor in which I installed. the old compressor locked up on mechanical failure. I believe I correctly installed this one, yet, it failed with S to G short. This is my SOP for the last. 1. Check for Correct voltege @ Control box. 2. Check Ohms across C S R & G (no shorts or open windings) 3. apply Hard Start Cap. 4. Finally Bump compressor..which worked for second.. with loud hard knock noise then lock up.. tripping breaker. I Replaced the compressor with equal tonnage and manufacturer. after blowing out line with Nitogen and installing suc and liq. line dryers. Now. I have a compressor that is short S to G after a misily 4 months. My question is.... is there anything I could have done diff. to prevent this early electrical Issue?[:-banghea What is this unit used for? Is the unit built by a standard manufacture or is it something you've put together? How long did the compressor last that locked up? Did you ever come to conclusion as to why it locked up? When you replaced this compressor why did you install a suction line dryer (reason to install a suction line dryer is typically to clean up a system after a motor burn - what your second compressor failed with). Something trashed the first compressor which sounds like a superheat problem. You either took a slug of liquid which broke the compressor or perhaps low superheat contributed to diluting the oil causing a lack of proper lubrication which lead to the compressor failing. Also could be operating in a low outdoor ambient without proper low ambient controls for head pressure. The is not enough information to even hazard a guess why the second one burned out. What were: Suction Pressure Head Pressure Superheat Sub-cooling Voltage reading Amperage reading when you started up the new compressor?
inspector57 Posted October 20, 2009 Report Posted October 20, 2009 Acid in the system would be my first suspect for a second failure that had a electric failure. Improperly cleaned system leaves moisture which combined with heat and time creates acid which eats up the compressor windings, valves and bearings. I did not read anything about a triple evacuation.
