John Dirks Jr Posted October 14, 2009 Report Posted October 14, 2009 I did an inspection the other day that had a septic system with a lift pump in a pit in the back yard. The concrete tank was installed partially above the ground. I understand the concept of the pump moving the waste from the holding tank up to the septic system. How about these electronics in the control system? Does anyone care to point out the different components and say what they are and how they work? I'm sure others as well as myself could learn from any input. Click to Enlarge 32.76 KB Click to Enlarge 50.81 KB Click to Enlarge 62.27 KB
Bill Kibbel Posted October 15, 2009 Report Posted October 15, 2009 I don't inspect on-site poo disposal systems, so I don't know anything about the components. I will mention that anytime I've seen a tank partially above ground, it wasn't a simple system. It's always been part of an aerobic, recirculating/dosing into media or spray irrigation system.
Terence McCann Posted October 15, 2009 Report Posted October 15, 2009 I don't inspect them either John but the stuff inside is all pretty basic. You have an hour meter that clocks the run time of the pump (probably used to schedule maintenance) it also has a off-manual-auto switch for the pump operation, below it is a terminal block, to the right, the orange device is a timed relay (I would imagine used for miniumn on time for the pump once it starts to prevent short cycling - (semi wag), to the right of that is the pump contactor (used to start and stop the pump), below it looks like a light or horn that goes through the bottom of the cabinet to siginal a problem with the system and above the contactor is stuff you already know.
