What is the point (if any) of the flashing seen below. It was copper, the upper edge wasnt even covered by the shingles above in most cases and it was on both sides of the gable in some locations??? The nail heads were also exposed without roofing cement. Thoughts?
83.87 KB
78.79 KB
68.98 KB
90.38 KB
They are to help prevent moss/ algae growth. I'm sure you've seen how clean older roofs are directly below metal vents, while there is moss or algae elsewhere? Same idea, but these strips don't tend to work well. Also, I consider the holes a problem, but rarely problems as a result.
I found this... Thanks...
"While inspecting the roof you will notice there are no algae stains directly below the metal flashings, flue pipes or roof vents. Why? Because metal oxides (rust) released when rain hits the metal prevent the formation and growth of algae."
