TARAN Posted October 1, 2009 Report Posted October 1, 2009 hi there guys, i was in the attic and half of the attic was loose fil and the other half was filled with r12. There was layer about 4 feet up. Would this cause a issue with circulation. Thank you
resqman Posted October 2, 2009 Report Posted October 2, 2009 Huh? Please add some more details and a picture. What little you shared makes no sense.
Scottpat Posted October 2, 2009 Report Posted October 2, 2009 hi there guys, i was in the attic and half of the attic was loose fil and the other half was filled with r12. There was layer about 4 feet up. Would this cause a issue with circulation. Thank you The "R" factor comes from the depth or thickness of the material as well as what it is made from. At 4' and if it is a blown-in type you will have greater than an R12 factor.
Jim Katen Posted October 2, 2009 Report Posted October 2, 2009 hi there guys, i was in the attic and half of the attic was loose fil and the other half was filled with r12. There was layer about 4 feet up. Would this cause a issue with circulation. Thank you all the bones. Wrap the plastic in eah layar. Stretching for better. moast can be vented.
