stryped Posted September 28, 2009 Report Posted September 28, 2009 I planned to use a motion detector with the two flood lights centered above my garage door. I started cutting thinking I would put a plastic box behind the metal siding inside the garage. However, being centered it is over a raised rib where two panels meet and it looks like I made a mess. It was hard to cut and I just stopped. Any ideas on how to properly mount this light and make it look ok and not leak?
Chad Fabry Posted September 29, 2009 Report Posted September 29, 2009 The beauty of mounting a light on the exterior of a metal building is you only have to run one wire.
