Some kid may have done that just to be funny. Or there may have been a problem with the panel where someone was shocked?
If they are selling the home and there *was* a problem with someone being shocked by touching the metal case of the panel, I would suggest having an electrician inspect it. Then remove that label!
A problem with no ground or a disconnected ground or a cold water pipe ground and the pipes were replaced with plastic - could cause such a problem... (So check grounding system too.)
