CheckItOut Posted September 12, 2009 Report Posted September 12, 2009 Disposal drain.... I think this will still function and I can't find anything that states otherwise (maybe you can). This is a remodeled home and there were some other plumbing issues like the accordion drain pipes under sinks. Click to Enlarge 48.47 KB
Bill Kibbel Posted September 12, 2009 Report Posted September 12, 2009 "Traps shall be set level with respect to their water seals..." There are 2 traps on one arm that needs to be corrected regardless.
SWagar Posted September 12, 2009 Report Posted September 12, 2009 That looks like a double sink, it would only really need one trap, which would make the install cleaner. Did you mention the lack of a high loop in the dishwasher drain to the disposal??
CheckItOut Posted September 12, 2009 Author Report Posted September 12, 2009 SWagar said: That looks like a double sink, it would only really need one trap, which would make the install cleaner. Did you mention the lack of a high loop in the dishwasher drain to the disposal?? Thanks. The "loop" is up high as it passes through the cabinet. They missed the clamp on the dw drain hose though.
ghentjr Posted September 12, 2009 Report Posted September 12, 2009 The loopy drain will hold debris. The trap behind the spray bottles doesn't look like it is a proper trap.
