yes, unfortunately for the painter, that panel is compromised and will have to be cleaned or replaced.
E3304.6 Integrity of electrical equipment. Internal parts of
electrical equipment, including busbars, wiring terminals, insulators
and other surfaces, shall not be damaged or contaminated
by foreign materials such as paint, plaster, cleaners or
abrasives, and corrosive residues. There shall not be any damaged
parts that might adversely affect safe operation or mechanical
strength of the equipment such as parts that are
broken; bent; cut; deteriorated by corrosion, chemical action,
or overheating. Foreign debris shall be removed from equipment.
I read that to mean that one is not allowed to clean the panel. It should be replaced.
  Chad Fabry said:
. . . I read that to mean that one is not allowed to clean the panel. It should be replaced.
The panel should be repalced because it's FPE equipment.
The sprayed-on stuff isn't paint, it's drywall texture. If necessary, it could be cleaned up with some water and a soft sponge. Nothing about the drywall texture or the cleaning process should affect the safe operation or mechanical strength of the equipment.
Unlike paint, I look at this stuff as foreign debris. It should be removed.
There's a development near me that was built in the 1970's and every home I've inspected there (maybe 10) all have excessive paint spray in the panel. Each panel is a Bulldog pushmatic too.
