Jerry Lozier Posted August 19, 2009 Report Posted August 19, 2009 Got one of those hiney pucker calls today .....'hey, we got a major drain leak' ...... Inspected 2 months ago, mid 70's home 2 story daylight basement (bank owned, no disclosure paperwork), 2" copper drain pipe under slab, pretty long run and probably not enough slope to drain, it has been leaking a long time, whole bottom is corroded out (1" x 12" hole in bottom of pipe in section of slab they cut out). So it finally plugged solid and backed up into upstairs kitchen sink. Nothing notable to report on any visible drain lines. The plumber that came out to clear their 'clog' said he was there several years ago and warned the previous owners at that time there was a problem They just wanted me to see the mess they have, which I did, and they do ( have a mess) Any words of wisdom on verbage for future reporting when I see copper drain pipes.... as I don't know if there was anything short of running a camera down it that would have caught this. Jerry
Jim Katen Posted August 19, 2009 Report Posted August 19, 2009 Jerry Lozier said: Got one of those hiney pucker calls today .....'hey, we got a major drain leak' ...... Inspected 2 months ago, mid 70's home 2 story daylight basement (bank owned, no disclosure paperwork), 2" copper drain pipe under slab, pretty long run and probably not enough slope to drain, it has been leaking a long time, whole bottom is corroded out (1" x 12" hole in bottom of pipe in section of slab they cut out). So it finally plugged solid and backed up into upstairs kitchen sink. Nothing notable to report on any visible drain lines. The plumber that came out to clear their 'clog' said he was there several years ago and warned the previous owners at that time there was a problem They just wanted me to see the mess they have, which I did, and they do ( have a mess) Any words of wisdom on verbage for future reporting when I see copper drain pipes.... as I don't know if there was anything short of running a camera down it that would have caught this. Jerry I don't know of anything you could have done. Stuff happens. - Jim Katen, Oregon
AHI in AR Posted August 19, 2009 Report Posted August 19, 2009 In cases like this, and especially with anything more than about 30 years old, I recommend having the sewer lines inspected with a video camera. A brief explanation as to the sort of things that can happen is also in my report. The better equipped rooter services can do this. Typically, I suspect they would only do the main and not the smaller lines, but at least you made the buyer aware of the potential for additional problems.
Bain Posted August 19, 2009 Report Posted August 19, 2009 And the important thing is that you answered their call, and showed up at their house. I'll bet you told them you were sorry, too, and that's likely just what they wanted to hear. That stuff happens to all of us.
kurt Posted August 20, 2009 Report Posted August 20, 2009 Yeah, it happens. You just got a tune up. I bet you tell the next customer with copper in the slab to 'scope it.
Neal Lewis Posted August 20, 2009 Report Posted August 20, 2009 Assuming bank owned and vacant. This is what I say in the report in the that situation. Since the house is vacant at the time of the inspection, the plumbing system can't be tested under normal operation. Some conditions may not be detectable during the inspection. For example: leakage within a wall/ceiling or clogged drain/waste lines.
Erby Posted August 20, 2009 Report Posted August 20, 2009 The drain lines are old. I can't see the parts of the pipe that are hidden underground. I don't know the condition of the underground pipe. If the pipe fails (as old pipes often do), sewage could back up into the house. I recommend that you have an appropriate contractor run a sewer camera through the drain pipe(s) and tell you what problems, if any, exist in the pipe(s). If the contractor finds problems, get them fixed.
Richard Saunders Posted August 20, 2009 Report Posted August 20, 2009 I'm kind of surprised the plumber didn't say, "Wow, the home inspector should have caught this".
Jerry Lozier Posted August 20, 2009 Author Report Posted August 20, 2009 kurt said: Yeah, it happens. You just got a tune up. I bet you tell the next customer with copper in the slab to 'scope it. thanks guys.... all good info on future situations.... Jerry
housecall Posted August 21, 2009 Report Posted August 21, 2009 Richard Saunders said: I'm kind of surprised the plumber didn't say, "Wow, the home inspector should have caught this". Nothing sends me into orbit faster than that phrase.
Jim Katen Posted August 21, 2009 Report Posted August 21, 2009 Erby said: The drain lines are old. I can't see the parts of the pipe that are hidden underground. I don't know the condition of the underground pipe. If the pipe fails (as old pipes often do), sewage could back up into the house. I recommend that you have an appropriate contractor run a sewer camera through the drain pipe(s) and tell you what problems, if any, exist in the pipe(s). If the contractor finds problems, get them fixed. Around here, sewer scoping is routinely done on nearly every older house transaction. But I've never seen them scope a 2" kitchen drain line. How do they get the camera into that line? - Jim Katen, Oregon
msteger Posted August 21, 2009 Report Posted August 21, 2009 I have verbiage in my report at the start of the plumbing category in my report that says underground plumbing pipes are out of view and are, therefore, outside the scope of the inspection. You can't inspect what you can't see. Copper drains were fairly common in the 50s and 60s if I recall. Stuff happens..
