Robert Jones Posted August 15, 2009 Report Posted August 15, 2009 I am guessing that they(builder) forgot to run a dryer vent up the wall to connect to the vent. This piece of plexiglass slides out and the lint catches just like the dryer screen. Click to Enlarge 32.78 KB Click to Enlarge 24.12 KB Click to Enlarge 43.51 KB
Brandon Whitmore Posted August 15, 2009 Report Posted August 15, 2009 If the dryer duct does not vent to the exterior, it's wrong unless they are planning on using one of those high tech. condensing dryers. Right now, they are venting warm moist air right into the home. Also, that is a fire hazard as lint could catch and spread the fire. The mylar/ foil vent connector is most likely wrong as well, depending on it's listing.
Robert Jones Posted August 15, 2009 Author Report Posted August 15, 2009 I was thinking the same thing, however, that opening that you see is actually normally sealed by the plexi-glass. I had to break the seal in order to get it off the wall. The "box" does vent to the exterior through the attic. The lint was getting trapped by the filter(by the amount on there, it has never been cleaned top pic). I am almost sure they just forgot to hook up behind that drywall and this was their idea of a fix.
Bain Posted August 15, 2009 Report Posted August 15, 2009 I don't understand. Where's the duct in the second photo? Or do you open the plexiglass door and and connect the Mylar to the pulled-out-of-the-wall box like in the first photo? And why is there a filter in the box to supplement the internal dryer filter?
Robert Jones Posted August 16, 2009 Author Report Posted August 16, 2009 There is no duct. Well the duct is connected in the attic, however, I believe that they forgot to run the duct from the wall to the outgoing duct in the attic. It's almost like this was their cure for the error and to keep the lint from going everywhere. The plexiglass was sealed until I opened it. There is a screen/filter attached to the plexiglass with notches in the box for it to slide into.
Brandon Whitmore Posted August 16, 2009 Report Posted August 16, 2009 I have seen that type of lint catch before in high rise condos, but they then vent out into the wall. I am a little confused by the description right now, but maybe I won't be in the morning.
barlyhop Posted February 18, 2010 Report Posted February 18, 2010 Perhaps the homeowner is trying to recapture the heat from the dryer before it exits the home??
