Mike Lamb Posted August 14, 2009 Report Posted August 14, 2009 Does anyone have any Honeywell installation instructions as far as thermostat location? I searched and did not find. Thanks.
Scottpat Posted August 14, 2009 Report Posted August 14, 2009 Locations for the T-stats all depend on the structure. Not in the kitchen, not in direct sunlight, not on an outside wall, and not in a closed room (unless the unit is for that room). I don't know of any specific location requirements. I see many near the main return, most of the time it is in a hallway.
Mike Lamb Posted August 15, 2009 Author Report Posted August 15, 2009 Thanks, Scott. This is what Honeywell sent me Thank you for contacting Honeywell. We recommend installing the digital thermostats 5 feet above the ground level. In addition to that, the following things should be taken care of while installing a thermostat: â⬢ The wiring hole in the wall should be properly insulated. â⬢ The thermostat should not be affected by an external heat source like direct sunlight. The thermostat should be installed on an inside wall. â⬢ The thermostat should not be affected by any drafts of hot air or dead spots. â⬢ The thermostat should not get excessive voltage through the wires. Honeywell Customer Care I thought there would be more.
