CheckItOut Posted July 28, 2009 Report Posted July 28, 2009 Just curious is anyone knows what would cause the flow of water at a shower head to occasionally pulse or skip. It would flow, then every so often, there would be a pause, then flow would go back to normal. The pause was very short - maybe 1/4 of a second. All other plumbing functioned fine.
SWagar Posted July 28, 2009 Report Posted July 28, 2009 Was the water flow at the tub spigot constant ? Where was the diverter ? In the spigot or the valve? Was there even a tub? It might be debris in the shower head or the valve.
CheckItOut Posted July 28, 2009 Author Report Posted July 28, 2009 SWagar said: Was the water flow at the tub spigot constant ? Where was the diverter ? In the spigot or the valve? Was there even a tub? It might be debris in the shower head or the valve. Flow at the spigot seemed constant. Yes, a diverter and in the spigot. Yes, a tub.
SWagar Posted July 28, 2009 Report Posted July 28, 2009 I would recommend that one removes the shower head and sees if the water flow is still interrupted. Look in the shower head for junk.
inspector57 Posted July 28, 2009 Report Posted July 28, 2009 Sure it was not a massaging head? If the setting is in between continuous and pulsating, they can be erratic
SWagar Posted July 28, 2009 Report Posted July 28, 2009 Wouldn't that be a skipping "golden" shower ????
