twendorff Posted July 27, 2009 Report Posted July 27, 2009 I have been told that I should not fire up a heat pump in the summer. I have recently found from a realtor that inspectors in my area have been firing them up. What is the general opinion of this? Thank you.
Jim Katen Posted July 27, 2009 Report Posted July 27, 2009 I have been told that I should not fire up the furnace in the summer. I have recently found from a realtor that inspectors in my area have been firing them up. What is the general opinion of this? Thank you. Who told you that you shouldn't fire up a furnace in the summer? Did they give you a reason? I'm unable to imagine why you wouldn't want to run a furnace during an inspection in the summer. - Jim Katen, Oregon
hausdok Posted July 27, 2009 Report Posted July 27, 2009 Ditto Jim, I can't see a reason either other than the inconvenience of a warmer house to those present and the seller when he returns home. The seller will get over it. ONE TEAM - ONE FIGHT!!! Mike
kurt Posted July 27, 2009 Report Posted July 27, 2009 I usually save the heating cycle for last in summer; that way I avoid working in an overheated environment. Other than that, fire it up for sure. Check air flow and everything else on the cooling cycle; only get the heat running long enough to make sure it's working correctly.
hausdok Posted July 27, 2009 Report Posted July 27, 2009 only get the heat running long enough to make sure it's working correctly. That's precisely what we do. I'll fire it just before I'm going into the crawlspace and run it only long enough to make sure that it works and won't short-cycle. Then I shut it down and switch it over to fan mode to cool it down while I'm down in the crawlspace. If I'm working alone that day, I'll ask the client to walk through the home and check to ensure there is air kicking out of all registers; if Yung is with me, she'll do that while I'm doing the crawl. By the time I come up through that crawl hatch the exchanger, and the house as well to a certain extent, has cooled down. The hardest ones for me to do are the radiant heating, hot water and steam systems. These take a while to come up to temp and stay warm for a long time after you shut them down. They have to be hell in the summertime for folks who live in those climes where they are the norm and FHA is the exception. ONE TEAM - ONE FIGHT!!! Mike
Terence McCann Posted July 27, 2009 Report Posted July 27, 2009 As others have said , there is no harm in running the heating cycle in the summer. In the summer, when I first arrive at the home, I start the A/C. I do this more for me than anything else [] Save the heat for last.
RSpermo Posted July 27, 2009 Report Posted July 27, 2009 I do not believe you should run a heat pump in the heating cycle above a certain degrees.
hausdok Posted July 27, 2009 Report Posted July 27, 2009 I do not believe you should run a heat pump in the heating cycle above a certain degrees. Hi, I've heard that and it seems to make sense to me; although I know next-to-nothing about heat pumps. I didn't even bring up heat pumps because the OP's question was about "firing" up "furnaces". I kind of expanded that logic to include boilers because they also burn fossil fuel to produce heat and aren't powered solely by electricity as electric heaters, electric central heating systems and heat pumps are. ONE TEAM - ONE FIGHT!!! Mike
Tom Raymond Posted July 27, 2009 Report Posted July 27, 2009 I do not believe you should run a heat pump in the heating cycle above a certain degrees. I don't follow the logic. A heat pump is a split AC with a reversing valve to switch the coil functions back and forth. While it would certainly make sense not to run the cooling cycle in winter, I don't see the harm in running the heating cycle in summer, the loads are going to be very similar. I think it would be wise to allow the system to "cool down" between cycles rather than slam it from cool to heat and back again. It's easy to imagine a scenario where the system is in cooling mode all day and switches to heat mode over night, especially with the crummy summer we're having. Tom
Chris Bernhardt Posted July 27, 2009 Report Posted July 27, 2009 The hardest ones for me to do are the radiant heating, hot water and steam systems. These take a while to come up to temp and stay warm for a long time after you shut them down. They have to be hell in the summertime for folks who live in those climes where they are the norm and FHA is the exception. When you get your IR camera, verifying operation of radiant heating systems will be a piece of cake. You'll be able to detect that their working, even how the coils are laid out, before you can feel any heat with your hand. Chris, Oregon
Tom Raymond Posted July 27, 2009 Report Posted July 27, 2009 You mean like this? Click to Enlarge 13.94 KB Tom
Jim Katen Posted July 28, 2009 Report Posted July 28, 2009 I have been told that I should not fire up a heat pump in the summer. I have recently found from a realtor that inspectors in my area have been firing them up. What is the general opinion of this? Thank you. Well, now a heat pump is a different story. If it's too hot outside and you try running it in the heating mode, it can develop high head pressures. If it's a good unit, its high pressure switch will pop and the unit will shut down. If it's a cheap unit, it'll just keep running, albiet unhappily. My own opinion is that this is less of a problem with units that have scroll compressors. I wouldn't hesitate to run those in warm weather. The larger issue is that there's really no reason to run a heat pump in warm weather. You can learn everything you need to learn about the system by running it in the cooling mode. In fact, it's usually easier to evaluate a heat pump in the cooling mode because you don't have to worry about the auxiliary heat coming on and messing up your readings. If you're worried about the real estate agents, ask them to produce the operating instructions. Most manufacturers will include a printed prohibition against running the system in the heating mode above a certain temperature -- I seem to recall about 80 degrees. - Jim Katen, Oregon
Scottpat Posted July 28, 2009 Report Posted July 28, 2009 I agree with Jim on evaluating a HP when it is warm.
Tom Raymond Posted July 28, 2009 Report Posted July 28, 2009 Scott and Jim, That is why I'm here every day, 'cause I learn something. Tom
msteger Posted August 2, 2009 Report Posted August 2, 2009 If it's 62 degs or above outside, I run heat pumps in cool mode and in backup heat mode. If it's below 62 degs outside, I run heat pumps in heat mode and backup heat mode. I think these follow the HP manufacturer instructions although some say 60, some say 65.
