Does anyone know what this red light that was blinking on this Richmond water heater is for? It says FR below the red light... Its a 2004 water heater with a powered exhuast.
Thanks
Download Attachment: icon_photo.gif jodi cam 252.jpg
215.87 KB
From page 13 of said manual:
"If a flame cannot be established within the trial for ignition period, the control will stop the flow of gas.
The control will continue to energize the blower (interpurge) and attempt ignition again. If a flame
cannot be established after three attempts, thecontrol will lock-out. A red LED light on the control
will flash continually indicating a lock-out condition occured. Unplugging the 120VAC power supply to
the water heater then restoring power will reset the control.
NOTE: The control will perform a self-diagnostic check upon start-up and the LED will flash 3-4 times.
During normal operation the LED remains off. A solid red LED indicates that the control must be replaced."
As we say in Quebec - Voila !!!!!
Jeez Jodi,
It's all right there on the label to the right of the temp control dial. Just read the flash sequence and compare it to the label and you'll know whether it's normal or something needs to be done to correct it.
  • 2 months later...
