Richard Moore Posted July 17, 2009 Report Posted July 17, 2009 I had the gas meter (and the regulator vent) right next to the openable section of a finished basement window today. This is an original window in a '67 home. I will be recommending the vent gets piped to terminate at least 3' away. The one question I have is whether this could be done by the HVAC guy (needs new furnace), or a plumber, or would this typically be the utility company's responsibilty? Anyhoooo...With the caveat that clearances may vary in your particular area, Puget Sound Energy has a very nice PDF with diagrams for required clearances. I thought some of you might like it. http://www.pse.com/SiteCollectionDocume ... s/3885.pdf
Tim123 Posted July 17, 2009 Report Posted July 17, 2009 I had the gas meter (and the regulator vent) right next to the openable section of a finished basement window today. This is an original window in a '67 home. I will be recommending the vent gets piped to terminate at least 3' away. The one question I have is whether this could be done by the HVAC guy (needs new furnace), or a plumber, or would this typically be the utility company's responsibilty? Anyhoooo...With the caveat that clearances may vary in your particular area, Puget Sound Energy has a very nice PDF with diagrams for required clearances. I thought some of you might like it. http://www.pse.com/SiteCollectionDocume ... s/3885.pdf Click to Enlarge 39.15 KB The rack(s), vent/regulator and meter are installed by the utility company on this coast, you can contact your local gas company and get the requirements, The gas line, in this case low pressure stainless steel is the plumbers. Hope this helps Tim
KGarten Posted July 18, 2009 Report Posted July 18, 2009 I would say it is the plumber that would get the call. At least down here all things gas are (usually) the plumbers area of expertise. Most of the vent extensions I have seen are run out of soldered copper which ac guys don't play around with much, if at all. The utility guys will probably think you are nuts for even asking, in my experience. Once they install their basic items (meter, stops, etc) they are done. Might be different in your area, 'tho.
Tom Raymond Posted July 18, 2009 Report Posted July 18, 2009 I'd start with the utility, but if they put there they probably think it's fine. Heck, my gas meter is in the basement and there is no external vent. There's hundreds of them like that around here and the utility won't change 'em. Tim, how many decades did you tell them it would take for that shrub to provide adequate crash protection for those meters? That is something the utility should be responsible for; if they pick a really dumb location they should be responsible for the barriers. Tom
msteger Posted July 20, 2009 Report Posted July 20, 2009 http://www.pse.com/SiteCollectionDocume ... s/3885.pdf Nice document you posted, Richard. I wonder what my local gas utility requires (UGI). I am going to email them with a link to that file and see what they have.
Tim123 Posted July 20, 2009 Report Posted July 20, 2009 I'd start with the utility, but if they put there they probably think it's fine. Heck, my gas meter is in the basement and there is no external vent. There's hundreds of them like that around here and the utility won't change 'em. Tim, how many decades did you tell them it would take for that shrub to provide adequate crash protection for those meters? That is something the utility should be responsible for; if they pick a really dumb location they should be responsible for the barriers. Tom Your are correct, it is the gas companies responsibility to determine if barriers are required, and should they determine that they are, they will not install the meters without the barriers. I have yet to see barriers on residential units where the gas meters are installed beside the garage door. The one that complains about the bushes will be the meter reader. Have a great day Tim
