Jim Katen Posted July 13, 2009 Report Posted July 13, 2009 I found this list of handy grammar rules. Study it carefully to help improve your report writing. 1. Verbs has to agree with their subjects. 2. Prepositions are not words to end sentences with. 3. And don't start a sentence with a conjunction. 4. It is wrong to ever split an infinitive. 5. Avoid clichés like the plague. (Theyââ¬â¢re old hat). 6. Also, always avoid annoying alliteration. 7. Also too, never, ever use repetitive redundancies. 8. Be more or less specific. 9. Parenthetical remarks (however relevant) are (usually) unnecessary. 10. No sentence fragments. 11. Contractions aren't necessary and shouldn't be used. 12. Foreign words and phrases are not apropos. 13. Do not be redundant; do not use more words than unnecessary; it's highly superfluous. 14. One should never generalize. 15. Comparisons are as bad as clichés. 16. Don't use no double negatives. 17. Eschew ampersands & abbreviations, etc. 18. One-word sentences? Eliminate. 19. Analogies in writing are like feathers on a snake. 29. The passive voice is to be avoided. 21. Eliminate commas, that are, not necessary. 22. Never use a big word when a diminutive one will suffice. 23. Kill all exclamation points!!! 24. Use words correctly, irregardless of how others use them. 25. Profanity is for assholes. 26. Understatement is always the absolute best way to put forth earth shattering ideas. 27. Use the apostrophe in it's proper place and omit it when its not needed. 28. Eliminate quotations. As Ralph Waldo Emerson said, "I hate quotations. Tell me what you know." 29. If you've heard it once, you've heard it a thousand times: Resist hyperbole; not one writer in a million can use it effectively. 30. Puns are for children, not for groan readers. 31. Go around the barn at high noon to avoid colloquialisms. 32. Even if a mixed metaphor sings, it should be derailed. 33. Who needs rhetorical questions? 34. Exaggeration is a billion times worse than understatement. 35. Proofread every space and letter carefully to see if you any words out.
Bill Kibbel Posted July 14, 2009 Report Posted July 14, 2009 Thanks, but it would be helpful if each of the grammar rules were accompanied by an example.
hausdok Posted July 14, 2009 Report Posted July 14, 2009 What a pair of comedians you two are. OT - OF!!! M.
kurt Posted July 14, 2009 Report Posted July 14, 2009 I found it to be surprisingly educational, even without examples! Pretty good stuff.......
randynavarro Posted July 14, 2009 Report Posted July 14, 2009 I found it to be surprisingly educational, even without examples! Pretty good stuff....... Uhh, Kurt?
randynavarro Posted July 14, 2009 Report Posted July 14, 2009 Uhhh, sarcasm?...... I knew it. Just knew it. My bad.
