Mark P Posted July 3, 2009 Report Posted July 3, 2009 I cannot find this in the IRC or code check. It is in the JLC Field Guide, but with no code reference. The house is new construction and the smoke detector is 5 inches from the bedroom wall directly above the door. The buyer is an electrician and swears it needs to be at least 6".... I told him I would try and find a reference to support tearing up the ceiling to move the detector. Does anyone have a code reference for this? I don't know what code this town uses, every town is different around here. Thanks
RSpermo Posted July 3, 2009 Report Posted July 3, 2009 NFPA 72 - Smoke detector on a ceiling shall be no closer than 4" to the adjoining wall.
RobC Posted July 3, 2009 Report Posted July 3, 2009 Wouldn't the manufacturer's instructions determine that? The 4" rule applies here also for both wall and ceiling distance to a maximum of 20" from the ceiling. Tests have shown that smoke will roll in corners and placing them in the 'dead' zone won't activate them. Same applies at the top of a cathedral ceiling for instance. When I see them inside bedrooms, I make sure they're interlocked with the outside ones. BTW You can charge more money if you refer to them as Smoke Alarms. [:-graduat
hausdok Posted July 3, 2009 Report Posted July 3, 2009 Hi, A hard-wired smoke alarm is technically connected to a receptacle. Maybe the 6" rule he's referring to has more to do with the closest an electrical box can be to a corner than it does a smoke detector. ONE TEAM - ONE FIGHT!!! Mike
Jim Katen Posted July 3, 2009 Report Posted July 3, 2009 Every smoke alarm comes with printed instructions that specify where it should and shouldn't be placed. They're quite specific about distance to corners, etc. Just get the manufacturer's instructions. -Jim Katen, Oregon
Mark P Posted July 3, 2009 Author Report Posted July 3, 2009 I looked at the "First Alert" website and found nothing. I tried to call, but they are closed for the holiday. So is it 4" to the center or the edge? This one was around 5" to the center and under 4" to the edge. I mentioned the NFPA 72 4 inch rule. I 'll try and call again on Monday, so by the time the builder comes back, I can either say "the manfactures say xyz...", or "Your right sorry about that..."
Jim Katen Posted July 3, 2009 Report Posted July 3, 2009 AHIS said: . . . I mentioned the NFPA 72 4 inch rule. . . . Has your area adopted NFPA 72? - Jim Katen, Oregon
Jim Katen Posted July 3, 2009 Report Posted July 3, 2009 AHIS said: I looked at the "First Alert" website and found nothing. I tried to call, but they are closed for the holiday. So is it 4" to the center or the edge? This one was around 5" to the center and under 4" to the edge. I mentioned the NFPA 72 4 inch rule. I 'll try and call again on Monday, so by the time the builder comes back, I can either say "the manfactures say xyz...", or "Your right sorry about that..." Go here: http://www.firstalert.com/smoke_alarms_item.php?pid=3 The link at the bottom of the page takes you to the manual here: http://www.firstalert.com/pdfs/2007/06/ ... 02_web.pdf - Jim Katen, Oregon
Mark P Posted July 4, 2009 Author Report Posted July 4, 2009 Here it is for everyones enjoyment. Thanks Jim for the link. "Avoiding Dead Air Spaces ââ¬ÅDead airââ¬
