John Dirks Jr Posted June 28, 2009 Report Posted June 28, 2009 I check my site on google searches very often. I use the same search query so I have a base to compare where I show up. Most of the time my placement is pretty consistent. However, sometimes disappear off the face of the earth. Then, the next day I'm back again. Is there an explanation for this?
dcmeagle Posted June 28, 2009 Report Posted June 28, 2009 There are several possible reasons. Google is constantly reworking their algorithms. Whenever they make a change you'll jump around as they recalculate as they're not only resetting your sites ranking, but all the sites that link to you. Then the changes have to propagate across thousands of their servers. Another reason is if you'd made changes to your site. This causes your site to usually dip for some reason for a day or two then it jumps back up. Third is a recent thing I've seen with people thinking they're much higher than they are. If you are logged into Google (you can tell in the top right corner) then your site will move higher on it's own as it's trying to give you custom results. Make sure you've logged out to see your real results.
John Dirks Jr Posted June 29, 2009 Author Report Posted June 29, 2009 Well, its not from being logged into google. I'm aware of that aspect. It may have been some changes that I made week ago. I suppose it also takes time for the changes to be recognized. So, it's not until then that the drop hits. Does that sound right? I just threw some more changes out there too. I got myself all confused now. I know, just walk away for a while right?
dcmeagle Posted June 30, 2009 Report Posted June 30, 2009 Just keep working on what you know will improve it in the long run. Yes it takes a few days to a few weeks for the changes to take affect in both directions. Google doesn't want to give anyone instant gratification as it would make it too easy to learn their game.
