Sanitary tees are not allowed to be used in a horizontal to horizontal drainage configuration (IPC table 706.3). I don't think it being on a pump discharge line would make any difference. I'm not sure the pressure 90 (or quarter bend, if you like) should be used either. I would have also preferred the check valve installed on the horizontal pipe as it will be holding quite a head of water in a vertical installation.
Jim, don't you mean a wye or a combo? I didn't think any "Tee's" were approved for vertical to horizontal.
Oops. Yes, I misspoke (typed). It should be a wye or a combo tee.
Mark,
Don't forget my check. I read this topic and agree with Jim and Richard. I no longer have a checking account so could you make it a money order?
