PNNL, Vitex developing process to help protect flexible solar power shingles
tn_20096515225_BIPV.jpgA transparent thin film barrier used to protect flat panel TVs from moisture could become the basis for flexible solar panels that would be installed on roofs like shingles.
The flexible rooftop solar panels - called building-integrated photovoltaics, or BIPVs - could replace today's boxy solar panels that are made with rigid glass or silicon and mounted on thick metal frames. The flexible solar shingles would be less expensive to install than current panels and made to last 25 years.
"There's a lot of wasted space on rooftops that could actually be used to generate power," said Mark Gross, a senior scientist at the Department of Energy's Pacific Northwest National Laboratory. "Flexible solar panels could easily become integrated into the architecture of commercial buildings and homes. Solar panels have had limited success because they've been difficult and expensive to install."
Researchers at PNNL will create these flexible panels by adapting a film encapsulation process currently used to coat flat panel displays that use organic light-emitting diodes, or OLEDs. The work is made possible by a Cooperative Research and Development Agreement recently penned between Vitex Systems and Battelle, which operates PNNL for the federal government.
PNNL researchers developed the thin film technology in the 1990s. At the time, the lab's team investigated 15 possible applications, including solar power. Vitex licensed the technology from Battelle in 2000 and focused its initial efforts on developing the ultra-barrier films for flat-panel displays. Now PNNL and Vitex are taking a hard second look at solar power.
The encapsulation process and the ultra-barrier film - called Barixâ„¢ Encapsulation and Barixâ„¢ Barrier Film, respectively - are already proven and effective moisture barriers. But researchers need to find a way to apply the technology to solar panels that are made with copper indium gallium selenide, called CIGS, or cadmium telluride, called CdTe.
Under the agreement, researchers will create low-cost flexible barrier films and evaluate substrate materials for solar panels, which are also called photovoltaics, or PVs. Both the film and substrate must be able to survive harsh ultraviolet rays and natural elements like rain and hail for 25 years.
The agreement also calls for researchers to develop a manufacturing process for the flexible panels that can be readily adapted to large-scale production. If successful, this process will reduce solar panel manufacturing costs to less than $1 per watt of power, which would be competitive with the 10 cents per kilowatt-hour that a utility would charge.
"Vitex is proud to continue its long, successful relationship with PNNL," said Martin Rosenblum, Vitex's vice president of operations and engineering. "Vitex is excited to further its Barixâ„¢ technology's proven barrier performance for photovoltaics toward mass manufacturing. Together, we look forward to creating a product that will help alleviate America's dependence on foreign oil and increase America's access to an abundant renewable energy source - the sun."
Battelle, which is the majority shareholder of Vitex, is optimistic that this research agreement will contribute to a new way of generating solar power. Battelle recently increased its investment in Vitex for new state-of-the-art thin film encapsulation equipment and expanded its intellectual property portfolio.
"We're confident that Vitex will be uniquely positioned to help meet the demand for flexible solar panels, OLED displays and lighting that should rise along with the economy," said Martin Inglis, Battelle's chief financial officer.
PNNL's research efforts will be paid for with up to $350,000 from the DOE's Energy Efficiency and Renewable Energy Technology Commercialization Fund. Last year, DOE announced that up to $1.5 million from the fund would be available to PNNL for projects that help commercialize technologies that reduce energy use or tap renewable energy sources. Because the fund requires commercial partners to match funding, Vitex will provide up to $350,900 of in-kind labor, equipment and materials for this project.
Vitex Systems Inc., headquartered in San Jose, Calif., licenses a proprietary encapsulation solution, Barixâ„¢, as well as deposition systems and next-generation flexible barrier substrates, that enable the cost-effective production of organic light-emitting diode (OLED) displays that are lighter and thinner than any other commercially available displays. Vitex's technology can also be used to address a wide array of photovoltaic and optoelectronic applications. The company was incubated at Battelle, the world's largest independent private non-profit research foundation, and was spun off as an independent company.
Battelle is the world's largest non-profit independent research and development organization, providing innovative solutions to the world's most pressing needs through its four global businesses: Laboratory Management, National Security, Energy Technology, and Health and Life Sciences. It advances scientific discovery and application by conducting $5.2 billion in global R&D annually through contract research, laboratory management and technology commercialization. Headquartered in Columbus, Ohio, Battelle oversees 20,400 employees in more than 130 locations worldwide, including seven national laboratories which Battelle manages or co-manages for the U.S. Department of Energy and the U.S. Department of Homeland Security and two international laboratories—a nuclear energy lab in the United Kingdom and a renewable energy lab in Malaysia.
For more information, contact Franny White, PNNL, (509) 375-6904
What is everyone’s opinion of the effects of?
• Heat build up from the film being attached to the roofing system?
• Delimitation of other building materials.
• Decreased lifespan of building materials.
• Serviceability of roof systems that the films are adhered to.
Does this negate any “Cool Roofâ€
I surely haven't studied PV panels, but it seems to me that it would be lest costly, and more practical, to put such panels not on roofs, but on standalone decks that don't have plumbing vents, attic vents and chimneys, etc. sticking up through them.
WJ
If they can make these stand up to hail for 25 years, that is better than the best asphalt shingles.
Key here is the plan is to create this, not a done deal.
We will just have to wait and see.
From a LEED standpoint you are not hurting your chances. If the roofing serves as alternative energy source, you may be able to get a point in the energy efficiency credit area. Either by helping meet the efficiency level to achieve the credit or to get an extra for exceeding. Solar panels do not take away from credit for a green roof. The square footage used for collectors is excluded. You also exclude the space for rooftop equipment.
  • 2 years later...
Well, installing solar panels Georgia at your home as well in your office are a great way to save the environment and save up a lot of money on your electricity bill. If you want to generate energy and electricity at your home, and make the electricity company pay you, this solar panels can be a very good investment.
Advertising link removed.
They need to be integrated into the actual roofing material so there is a single installation.
Hi,
It's already being done. Thin film polyvoltaic systems that are integrated into the roof system are known as BIPV (Building Integrated Poly Voltaics) and there are already a number of systems on the market. Success so far with making them blend in well with typical shingle roofs is kind of sketchy; but there are tile systems that look pretty good when installed in tile roofs. The technology is there, now they have to concentrate more on making it more attractive.
Below are a few examples of BIPV technology. In two years these samples will probably be obsolete and in ten years one will probably have a hard time seeing the difference.
http://www.greenadvisor.com/business/gr ... ovoltaics/
http://www.oksolar.com/lion/item/15685
http://www.uni-solar.com/produkte/produ ... e/?lang=de
http://www.premierpower.com/solar_energ ... r_tile.php
http://www.dowsolar.com/overview/index.htm
http://www.bipvinc.com/products/sun-energy-shingle
http://www.bipvinc.com/products/sun-ene ... ingle.html
http://www.trinityexteriorsinc.com/930/ ... ce-asphalt
They are definitely heading in the right direction, just not quite there yet as far as the aesthetics and cost. I am sure we will see solar shingles as common building practice.
Before you know it we will be asked to inspect solar shingles as part of our home inspection.
Well, if you study carefully the Certainteed installation video and instructions you could probably do a good job of inspecting their system now.
