Inspected a townhouse today. It was a full rehab from old apartments. It was un-occupied and had been since the upgrade (approx. 8 months.)
While in the basement I noticed water on the floor where the gas meter was. Touching the bottom of the gas meter I came up with water on my hand. I used the gas sniffer and came up with a small leak at the main shut off valve but nothing around the gas meter. Condensation might be the probable cause but there had been no a/c running in the condo and everything was about the same temp. The floor had been painted about 2 months ago so the moisture had to come in the summer months.
Any thoughts?
Terry,
A drop or two of water below the meter would just prove the theory that's been proven already with the advent of AC.
Compressed gas goimg through a pressure reduction, cools.
The pipes would be ever so slightly below ambient temps. In high humidity, condensation would occur.
If there was more than a few drops of water I have no idea what caused it.
As always, I reserve the right to be wrong.
It was a puddle under the gas meter. The town-house has been un-occ. since the rehab so no gas was being used since heat was needed. Tried to run the a/c and it wouldn't start so I know that's not the problem (low temps - stuff sweating).
