montela Posted May 20, 2009 Report Share Posted May 20, 2009 Want to refinish a night table. It has a veneer coating which has cracked and chipped. I'd like to get it off. Any suggestions, Link to comment Share on other sites More sharing options...
waynesoper Posted May 20, 2009 Report Share Posted May 20, 2009 Is it wood veneer? If so when you remove it you will have plywood below which is not very attractive. Got a picture? Link to comment Share on other sites More sharing options...
Tom Raymond Posted May 20, 2009 Report Share Posted May 20, 2009 I would try using heat to soften the glue. Place an old towel over the veneer and run an iron over it. If that fails, slowly add a little steam. If it's a natural glue this should work, if it's synthetic who knows. It may be easier to patch the defects and veneer over it. Tom Link to comment Share on other sites More sharing options...
Jim Katen Posted May 20, 2009 Report Share Posted May 20, 2009 Want to refinish a night table. It has a veneer coating which has cracked and chipped. I'd like to get it off. Any suggestions, How old is it? Post a picture. - Jim Katen, Oregon Link to comment Share on other sites More sharing options...
devidmike Posted May 21, 2009 Report Share Posted May 21, 2009 The wood under the veneer is called secondary wood---you will need to replace the veneer is you remove it. And removing it---the veneer has been glued on---is most easily done by sanding it off. That will be prohibitively expensive in sandpaper and mess. Link to comment Share on other sites More sharing options...
gtblum Posted May 21, 2009 Report Share Posted May 21, 2009 I'm with Tom. Take the rest of the loose stuff off, patch it, and put a new top on it. OR, visit Wood Web.com. You can read about veneer til your eyes pop out. Link to comment Share on other sites More sharing options...
Bill Kibbel Posted May 21, 2009 Report Share Posted May 21, 2009 How is this relevant to the plumbing forum in a home inspectors' message board? Link to comment Share on other sites More sharing options...
hausdok Posted May 21, 2009 Report Share Posted May 21, 2009 Hi Bill, It's not, I've moved it. Is it wood veneer? If so when you remove it you will have plywood below which is not very attractive.Not necessarily, They were veneering wood hundreds of years before plywood was ever invented. Use a steam iron and a damp towel to loosen the veneer. Keep it damp with steam and scrape it off with a putty knife. Sand off the glue residue and let the table dry thoroughly (a week or two). Purchase a new flitch from a woodworking store or a door making factory and store it in the same room with the table for that week or two. Make yourself a veneer press - a couple pieces of heavy smooth sided plywood with a few hardwood battens and C clamps will do the trick. Clamp the battens together side by side with the faces flush and sand them so that there is a very slight crown in the middle. Cut the flitch slightly over sized, apply hide glue to both surfaces to be bonded, align the flitch, place it, and then place a layer of wax paper on top to isolate it from the press and prevent glue squeeze out from adhering the press to the tabletop. Sandwich the tabletop and flitch between the plywood clamps, place the battens - crown side down - on the surface and then clamp them in place moving from the middle to the outside. Tighten your 'sandwich' snuggly but don't over-tighten it and squeeze all of the glue out - you need a thin layer of glue there to hold the veneer in place. The slight curve on the battens will exert slightly more pressure in the middle and force pressure outward as you tighten the clamps on the battens. This will ensure the entire face is bonded without any air pockets. Allow the sandwich to dry for a couple of days. Remove the press and wax paper, carefully trim away the excess veneer with a razor knife (unless you want to purchase a veneer saw), carefully sand the face smooth and the edges flush. Sand with the grain, going progressively finer with your sandpaper. Use a light touch or you'll sand through the veneer. Don't hurry or when you apply your finish to the tabletop the finish will look like crap. Buff it out with some 0000 steel wool, wipe it down with a tack cloth and then apply your finish. Did I forget anything, Richard - it's been about 16 years since I've veneered anything. When you're all done, consider the fact that you probably could have bought another coffee table for a fraction of the time and effort that you put into restoring that one. ONE TEAM - ONE FIGHT!!! Mike Link to comment Share on other sites More sharing options...
gtblum Posted May 21, 2009 Report Share Posted May 21, 2009 After your done with all of that, do not take it to the Antiques road show. Those blonde haired twin brothers will bust you in a heartbeat. Link to comment Share on other sites More sharing options...
Richard Moore Posted May 21, 2009 Report Share Posted May 21, 2009 Did I forget anything, Richard - it's been about 16 years since I've veneered anything. What you listed sounds good to me but I'm no expert on veneering and I wasn't into repairing or re-finishing antiques. I "created" mostly with solid, highly grained, hardwoods. When I needed "veneered" panels for more mundane cabinets I would browse the plywood racks at various specialty lumber yards until I found what I liked. Frankly, the fact that the OP posted here would lead me to have serious doubts about his/her skill level and their ability to do this and have it really blend in seamlessly (no offense intended). If the piece is really worth saving and they want to restore it, then I would probably suggest they contact a few local antique stores and find a good re-finisher. Link to comment Share on other sites More sharing options...
