chrisprickett Posted July 15, 2004 Report Posted July 15, 2004 Here's the scenario: French door going from an bedroom to a walk deck. The door threshold is about 14" higher than the bedroom floor. The door swings into the bedroom. To accomodate for the 14" drop into the bedroom, the builder installed a 11" step, the full width of the door opening. My concern is that when you walk into the room, from the deck, there is not a 36" deep platform, as per 2003 IRC 311.4.3 Landings at doors: The width of each landing shall not be less than the door served. Every landing shall have a minimum dimension of 36 inches (914 mm) measured in the direction of travel. I'm not sure if this code reference applies, although it seems to me that it would. I do know that when I walked in from the deck, I nearly busted my a$$! Download Attachment: Shuman 7 15 04 015.jpg 140.9 KB
Jim Baird Posted July 15, 2004 Report Posted July 15, 2004 I'd say the landing rule applies here. Write 'em up!
kurt Posted July 16, 2004 Report Posted July 16, 2004 Is a landing required? Since I work in Chicago, which has its OWN codes, I honestly don't know squat about IRC land. If this is considered a landing, it has to be 36". Why couldn't there be a step? Any way you cut it, it's dangerous & a hazard, but is a landing required by IRC in this situation?
crusty Posted July 16, 2004 Report Posted July 16, 2004 Originally posted by kurt Is a landing required? Since I work in Chicago, which has its OWN codes, I honestly don't know squat about IRC land. If this is considered a landing, it has to be 36". Why couldn't there be a step? Any way you cut it, it's dangerous & a hazard, but is a landing required by IRC in this situation? I can find no exceptions to allow this condition without a landing in the IRC. A landing is required anytime a door opens over a step. Steve
chrisprickett Posted July 16, 2004 Author Report Posted July 16, 2004 Kurt, The code I quoted seems to apply. In reality, a 36" landing inside a bedroom is pretty stupid, but so is the shortsightedness of the guy who designed a 6000 sq ft $2M house, and didn't figure for dealing with a 14" drop from a deck into a bedroom. The best fix would be to drop the threshold, but then there would be an issue with water backing into the house. I'm coming from a CYA position, when the buyer breaks his neck, and looks for a patsie!
Brian G Posted July 16, 2004 Report Posted July 16, 2004 Originally posted by chrisprickett The code I quoted seems to apply. In reality, a 36" landing inside a bedroom is pretty stupid, but so is the shortsightedness of the guy who designed a 6000 sq ft $2M house, and didn't figure for dealing with a 14" drop from a deck into a bedroom. I agree on both counts. I'm coming from a CYA position, when the buyer breaks his neck, and looks for a patsie! Prudent, no doubt. Brian G.
Jim Katen Posted July 16, 2004 Report Posted July 16, 2004 Originally posted by chrisprickett Kurt, The code I quoted seems to apply. In reality, a 36" landing inside a bedroom is pretty stupid, but so is the shortsightedness of the guy who designed a 6000 sq ft $2M house, and didn't figure for dealing with a 14" drop from a deck into a bedroom. The best fix would be to drop the threshold, but then there would be an issue with water backing into the house. I'm coming from a CYA position, when the buyer breaks his neck, and looks for a patsie! Why not install a doorset that swings outward? - Jim Katen, Oregon
chrisprickett Posted July 16, 2004 Author Report Posted July 16, 2004 [Why not install a doorset that swings outward? - Jim Katen, Oregon Ahhhh, simplicity! Can't argue with that!
monte Posted May 12, 2005 Report Posted May 12, 2005 I agree with all of the above positions. The UBC code has a exception to it's stairway and landing requirements if there is less than two or more risers. Does not IRC have the same exception?
Ytek Posted January 30, 2007 Report Posted January 30, 2007 Why not install a doorset that swings outward? - Jim Katen, Oregon I'm curious, would a sliding door still have the same requirement?? Jim
Steven Hockstein Posted January 30, 2007 Report Posted January 30, 2007 Originally posted by Ytek Why not install a doorset that swings outward? - Jim Katen, Oregon I'm curious, would a sliding door still have the same requirement?? Jim no
