JOHN SVALBE Posted April 15, 2009 Report Share Posted April 15, 2009 HOW DO I DETERMINE THE MAXIMUM HEIGHT AND SIZE (DIAMETER) OF A WOOD BURNING PREFAB FIREPLACE INSERT? CMC CHAPTER 8 HAS MANY TABLES, BUT DOESNT EXPLAIN DIFFERENCE BETWEEN VERTICAL AND LATERAL DISTANCES. IS THE LATERAL DISTANCE IN ADDITION TO THE VERTICAL, OR A COMBINATION OF HORIZ. AND VERTICAL (IN WHICH CASE LATERAL SHOULD BE GREATER THAN VERTICAL)? Link to comment Share on other sites More sharing options...
waynesoper Posted April 16, 2009 Report Share Posted April 16, 2009 Measure it! You are confused and should read the installation manual for the product you are purchasing. Link to comment Share on other sites More sharing options...
msteger Posted April 16, 2009 Report Share Posted April 16, 2009 HOW DO I DETERMINE THE MAXIMUM HEIGHT AND SIZE (DIAMETER) OF A WOOD BURNING PREFAB FIREPLACE INSERT? CMC CHAPTER 8 HAS MANY TABLES, BUT DOESNT EXPLAIN DIFFERENCE BETWEEN VERTICAL AND LATERAL DISTANCES. IS THE LATERAL DISTANCE IN ADDITION TO THE VERTICAL, OR A COMBINATION OF HORIZ. AND VERTICAL (IN WHICH CASE LATERAL SHOULD BE GREATER THAN VERTICAL)? WHY ARE YOU SCREAMING?!? Link to comment Share on other sites More sharing options...
john_opwin Posted January 2, 2010 Report Share Posted January 2, 2010 Good query! I have never considered this topic. I believe you will get your desired reply on Google. Link to comment Share on other sites More sharing options...
mgbinspect Posted January 2, 2010 Report Share Posted January 2, 2010 Lol... screaming.. (proper posting etoquete... no caps aloud.) lol.. I love it... Link to comment Share on other sites More sharing options...
