Heres the scenerio:
New home... garden tub in master bath, supported by rim only. Couple inch gap below tub to subfloor ( particle board and engineered floor joists)
anyone heard of support by pouring a concrete 'slab' beneath as opposed to support by wood. Concrete seems a little overkill
no idea the manf. of garden tub so cannot refer to manf instructions
thanks Jerry
Heres the scenerio:
Unless the tub came with a specially reinforced bottom, it's supposed to be set in some kind of grout -- concrete, mortar, or even plaster.
I've seen quite a few acrylic tub installation instructions that call for the tub to sit in a mortar bed. I've also seen a couple tubs that were not installed with a mortar bed and they had cracked around the lip.
-Brad
-Brad
Gor it........ thanks guys for the fast comeback........ Jerry
Hi,
I looked at a new all-fiberglass accessible shower installed in a 57 year old home today. They'd filled the void under the pan with expandable foam from a can and then cut through all of the foam to expose the hole in the pan so they could connect the plumbing from the basement below.
