John Dirks Jr Posted April 4, 2009 Report Posted April 4, 2009 I inspected a town home with one of these systems. It was a first for me. What do you think of these units? I called this one out because the water heater supplying it was too small. I caught on just in time. Someone is looking out for me I guess. http://www.firstco.com/products/aqua_therm.asp
hausdok Posted April 4, 2009 Report Posted April 4, 2009 Good catch on the water heater size. As far as what I think? Well, it's nothing but a giant car heater. Do you like the heater in your car? ONE TEAM - ONE FIGHT!!! Mike
Terence McCann Posted April 4, 2009 Report Posted April 4, 2009 Good catch on the water heater size. As far as what I think? Well, it's nothing but a giant car heater. Do you like the heater in your car? ONE TEAM - ONE FIGHT!!! Mike A lot of commercial systems are ceiling mounted fan coils with chilled/hot water coils. A lot of apartments have floor mounted fan coils with chilled/hot water coils in the rooms. There is nothing wrong with a hot water coil for heat. A constant 140 degree coil may seem cold in the dead of winter as apposed to a boiler that is putting out 200 degree water though. No worse than a heat pump for sure.
John Dirks Jr Posted April 5, 2009 Author Report Posted April 5, 2009 The existing water heater was only a 38 gallon. According to the research I did via manufacturers documents, the air handler in question should have at least a 50 gallon. Not only that but the current water temp being produced by the existing water heater was only 105 degrees. Come next winter, I'm sure they would have notice something wasn't quite right. Learning and loving it.
