Heres the house. 60's bank owned. Water turned off.
70.96 KB
The cleanout in the front yard was leaning on an angle quite a bit. How common is this? Shouldn't it be basically vertical? There was also a significant depression in the yard in front of the cleanout and the sidewalk has settled 4 or 5 inches.
Since the water is off, I could not test drain flows. I'm wondering if the yard depression and the leaning of the pipe are related. Add to that, I can't test drain flow. Are you getting the picture. I know I need to write about all of this.
Can you help me find the best words?
72.95 KB
72.95 KB
I would write down that there is a depression in the yard in the proximity of the sewer line. I would let them know that there is a chance of a sewer line break/ leak causing it, and that they need to have a sewer scope performed to find out for sure.
Hi,
Well, even if the water was on you might not have been able to tell anything from drain flow - sometimes they break and continue to accept waste just fine for a long time, untill one day they don't.
It's early and I haven't had my second cuppa yet, but something like:
There is a significant depression in the front yard adjacent to the waste line cleanout and the cleanout is askew. I suspect that the depression in the yard and the leaning cleanout might be caused by a break in the waste line below grade. If the waste line is broken below grade it's going to be expensive to repair. I recommend that, to be sure the waste line is intact, you have the waste line inspected now by a pipe inspection service. If the pipe inspection service reports that the pipe is broken, get it repaired immediately.
