JesseWBryant Posted March 1, 2009 Report Posted March 1, 2009 I can't remember the specific reason or if there is a code for it, but why cant you run the low voltage wiring from the thermostat to the condenser unit in the same conduit as the electrical wiring that runs from the service disconnect box to the condenser unit? Just one of those things where if I am going to tell them its wrong, I want to make sure I know why. Thanks
JesseWBryant Posted March 1, 2009 Author Report Posted March 1, 2009 Nevermind, I found it. IRC 4204.1.
Jim Katen Posted March 1, 2009 Report Posted March 1, 2009 I can't remember the specific reason or if there is a code for it, but why cant you run the low voltage wiring from the thermostat to the condenser unit in the same conduit as the electrical wiring that runs from the service disconnect box to the condenser unit? Just one of those things where if I am going to tell them its wrong, I want to make sure I know why. Thanks The reason is that you don't want line voltage on control wiring. - Jim Katen, Oregon
