dtontarski Posted February 24, 2009 Report Posted February 24, 2009 I observed a sewage pump installed for a newly added basement bath. I have not seen many sewage pump installations, and those I have observed had either an appropriately sized AAV or an atmospheric vent. This one's vent pipe Click to Enlarge 73.79 KBis connected above the point where the pump discharge line pumps into the main waste line to the septic. This is a closed loop. Other than a slight gurgling from the utility sink, which may be able to be resolved with an AAV installed near the utility sink, this seems to be functioning just fine. Is this an acceptable installation?
msteger Posted February 24, 2009 Report Posted February 24, 2009 That's a wet vent. Instead of a separate vent line leading to atmosphere, both pipes connect to the sewer drain line (one above the other). It's a wet vent because the line has water and air in it. Whether the install is OK in your area may depend upon the AHJ. In my area, this is permitted, even though several plumbers I've talked to don't like them. The gurgling is air.
KGarten Posted February 27, 2009 Report Posted February 27, 2009 So the drain connects in and the vent is above it and a section of pipe connects the two?
Neal Lewis Posted February 27, 2009 Report Posted February 27, 2009 I'm not sure if i can see a check valve on the discharge line, and the shut off valve to isolate the discharge line is missing.
msteger Posted February 28, 2009 Report Posted February 28, 2009 So the drain connects in and the vent is above it and a section of pipe connects the two? Essentially, yes.
