kurt Posted January 23, 2009 Report Posted January 23, 2009 Target rich environment here, but my specific question is.......... Fiber reinforced cement "architectural panels" laid over a WRB of simple housewrap (maybe tyvek, never could see a good brand name). There are 1/4" spaces between all the panels. I'm thinking in some number of years, the housewrap WRB is going to be gone to blazes from UV and weather. This would clearly be a violation of the "max 120 day exposure" limitation of housewrap, no? It would go to blazes, yes? Click to View 21.82 KB Click to View 49.73 KB Click to View 25.8 KB
Jim Baird Posted January 23, 2009 Report Posted January 23, 2009 Looks like the designer would have spec'd flashing behind all them reveals.
Rocon Posted January 23, 2009 Report Posted January 23, 2009 This is a rain screen wall. It is becoming more and more popular with Architects you will see more of these. But like any new system the people installing it are the weak link. Be sure of the WRB specs before you call it a problem. I have done many of these in Venice, CA in place for over 8 years with no problems. You can remove the pannel by removing the gasketed screw. Just be cautiouse to reinstall the screws through the same hole. There should be a gasket on the back side of the Hardy board. The cracked panel is an aesthetic issue you should sugest be repaired.
kurt Posted January 23, 2009 Author Report Posted January 23, 2009 It's "sort of" a rain screen wall (i said target rich). This place has walls that aren't decoupled; the panels are tight to the tyvek. Other areas are open and can drain. So, technically, it's not a rainscreen. I think that was the idea, but it fell down on several details. I finally found what I needed. It's gotta be Tyvek UV Facade material, and it ain't. Found my answer.......
Jim Morrison Posted January 24, 2009 Report Posted January 24, 2009 Kurt, What is that cold-looking, white, powdery substance covering the ground in your photo? Jimmy
Chad Fabry Posted January 24, 2009 Report Posted January 24, 2009 What a Piece of crap. It will leak. Then, it will rot. I'm betting there will be serious issues long before I lose my sex drive and I'll soon be 49.
Brian G Posted January 24, 2009 Report Posted January 24, 2009 Originally posted by Jim Morrison What is that cold-looking, white, powdery substance covering the ground in your photo? Cocaine. It's a very rich neighborhood. [:-party] Brian G. She Go 'Round, She Go 'Round, She Go 'Round...... [:-sing]
hausdok Posted January 24, 2009 Report Posted January 24, 2009 Originally posted by Jim Morrison Kurt, What is that cold-looking, white, powdery substance covering the ground in your photo? Jimmy Asks the smart-ass while he curls up with his little harem of conchitas down in meh-hee-ko. Grrrr. OT - OF!!! M.
Bain Posted January 24, 2009 Report Posted January 24, 2009 I don't get it. What prevents water from seeping into the upper edges of the fiber cement panels and oozing through the hole in the WRB created by the fastener? Even if steel furring was installed on a concrete wall, wouldn't that allow mold and yuck to grow in the airspace? And if that cladding were installed on wood . . . ?
kurt Posted January 24, 2009 Author Report Posted January 24, 2009 Bain, yer readin' my mind...... And Jimmy, brother of brothers, I'm comin' down Puerto way and gonna kick your ass up and down the beach, and then do it again.
Jim Katen Posted January 25, 2009 Report Posted January 25, 2009 Is that Swiss Pearl? I did a project that used it a couple of years ago. Installed properly, it looks great & works great. I think your installation is screwed. http://www.swisspearl.com/uploads/media ... eng_01.pdf - Jim Katen, Oregon
kurt Posted January 25, 2009 Author Report Posted January 25, 2009 No, Swisspearl is gorgeous. This was more easterneuropearl. Not much engineering to it. I suspect this started out as a really nice architects vision, then it got developer-ized.
